Jetronics double valve problem
Hi
I was changing my PB evolution for a PB Cockpit in my F18F and after some programming and headaches, the JT double valve as sopped switching from Up and Down. This valve is the older model with metal body and Festo type nipples (it is 3 years old). I have already plugged the valve in another rx with ATV at 100% for either side and nothing. Also have tried to reset the valve by pressing both buttons and then power on and nothing. I have also tried to press both buttons with rx on and nothing. Anyone knows what might help? Ifg I plug in a servo it moves ok. The valve is stuck in one position and does not switch Regards nuno |
RE: Jetronics double valve problem
Are you sure the end points in the radio are at 100% each way?
Hi
Yes I have tried with 100% and 140%. I ran a 12FG Regards Nuno |
Come on guys, am I the first one????
Regards Nuno |
Does it work ok if you manually activate it?
Mike |
Hi
No it does not. Regards Nuno |
Nuno, if it doesn't work when you manually activate it, it must be a problem with the valve itself and not your radio set up.
Mike |
| All times are GMT -8. The time now is 01:17 AM. |
