RE: Jet Cat 120 repair
Chrigui,
Nice work, I guess this J.C. 120 has a lot of hours on it? |
This is a good indication of what happens if you have a needle or vap tube problem the others have to work harder to produce the rpm the ECU wants and so run a lot hotter in the CC, causing the cracking of the NGV.
Chrigui, what did you use to clean the CC |
the original egv was reduced in diameter (i dont know who has done the work... ) and the thickness was only 0,25 mm
maybe to fit in the non original flange stick support with high temp the egv cracked..also i found the gap between turbine wheel and egv was over 0,6mm in radius (maybe modified to eliminate turbine touching egv) i know that engine was buyed by ebay in holland... i clean with fine sand and washed....alternative is ultrasound when carbon deposits are less than in the photo |
Im very impress the NGV guide vanes are still intact even with a bad CC. We need a RCUNIVERSE home turbine repair Forum :D.
the ngv blade are intact because they are thicker
ps..sorry for may bad english..[:o][:o] |
Your english is fine! ;)
Ciao Chris...buon lavoro!!! ;)
Vin... |
ciao vincent.... grazie ...tutto bene?? come stai?
ORIGINAL: basimpsn Im very impress the NGV guide vanes are still intact even with a bad CC. We need a RCUNIVERSE home turbine repair Forum :D. Chrigui maybe you will post a link to this thread on it as well. |
1 Attachment(s)
(DIY Turbine stripdown & Maintenance)
It would be my new addiction;). Chrigui good repair work. I am learning something new since the (HOW ITS MADE) video ;) for example the P-120 uses 6 burner not sure if the new P-120 SE using 12 sticks. By the way nice work also on machining the new NGV. What material are you using? |
the 160 has 12 stick
new 120se i dont know new p80 has sligtly modified diffuser and different CC design http://a8.sphotos.ak.fbcdn.net/hphot...24_80067_n.jpg |
Good information ;) Any info on the NGV
ngv is cast made from Albisser...
ORIGINAL: chrigui ngv is cast made from Albisser... I always though the hot sections were made for Inconel http://en.wikipedia.org/wiki/Inconel |
http://www.jetmax.ch/produkte.htm (Dieter Albisser)
Chrigui do you know what part number the old p120 compressor is
1 Attachment(s)
Dieter Albisser |
Garrett T3 446279-0001
69,00 mm diametro maggiore 51,65mm diametro minore 6,25 mm diametro albero Trim 56 12 palette (6+6) |
Hello basimpsn
What material did you use to make your injector needles, where did you purchase from? Thanks, Neal |
you can use brass tube or siringe needle
just tested the engine
120.000 rpm 672°c egt |
1 Attachment(s)
Good work, chirigui.
I have repaired this JC 120SE ( 6 sticks ). The NGV was in very bad condition. I have used a cast NGV like you, but this is a chinese one. It´s casted in inconel 713C, very very dificult to machine. Regards. Félix |
no problem to machine my egv.. you must to use right tools..
I think Albisser NGV are not inconel, usually NGV are made from high grade SS. ( ANC 5B), and they are fairly easy to machine ( I havve machined several) . The supplier told me that this was Inconel 713 C, and actually is not easy to machine.
Regards. Félix |
