RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Programming Crow in JR12X (https://www.rcuniverse.com/forum/rc-jets-120/10770467-programming-crow-jr12x.html)
Don Perry 10-17-2011 06:16 PM
I have an Ultra flash and I need to program some crow mixed in with full flaps. I'm sure this has been explained somewhere but I was not able to find it.
I have tried off and on over the last few months with no success.
I'm open to the setups others are using.
Don
SinCityJets 10-17-2011 06:18 PM
RE: Programming Crow in JR12X
Don,
I wrote a tutorial. Search under crow for 9303.
Chad
SinCityJets 10-17-2011 06:19 PM
OK, mission complete. I am going to write down how I did, what I did to activate the crow. First a BIG "THANK YOU" to Bob for taking the time to call me and walk me through it. He gave me the one piece of information I was missing.
Ok, here we go. I am going to start with setting up a brand new model.
1) Enter System Menu (hold "ENT" and turn readio on). You should know how to set up the Model Name and Type Select.
2) Under "DeviceSel", select "Flight Mode" and then selct "Flap SW".
3) I have the following switches activated: Gear - Act, Flap - Sys., Aux2 - Inh, Aux3 - Act (brakes), Aux4 - Act (smoke and I have it using the "BUTN" switch.
4) Hit "List"
4) Now go to "Wing Type"
5) Wing type is set to "Normal"
6) Go to Dual - Aile and select "AUX2". This automaticall sets up Aux2 as your opposite aileron.
7) Now, hit "ENT"
8) Set up your "Flap Sys" to your desired settings. Adjust both your flaps and elevators to the desired throws.
9) Now, the only mix you have to do: Go to mix 1 or 2 (multi-point mixes), and set up a "Flap to FPRN" mix. The diagram on the right will show your flap and aileron (or flaperon) settings. The horizontal line is ailerons and the vertical line is flap position. As you adjust your flap switch, you will see the vertical line move across the diagram. Here are my settings for this mix:
Point 0 -60
Point 1 INH
Point 2 INH
Point 3 0
Point 4 0
Point 5 0
Point 6 0
The -60 above shows how much aileron I have for my crow.
I hope this helps a little for those trying to do this. It is hard to try and piece together pieces of information to do what you want.
SinCityJets 10-17-2011 06:21 PM
I just copied and pasted it. My number of "-60" was for the particular plane I was using at the time. Your numbers may vary.
KC36330 10-17-2011 06:22 PM
a lil different then Chad's......
First hold menu and turn power on, under code 17: Devise Select inhibit Aux 3 (or your channel of your choice) exit code 17 back to menu.
Next enter code 22: Wing Type, the Duel feature of Ailerons to Aux 3 (or the channel you selected above) and exit out of the menu and press menu again to exit out to the normal mode (or cycle the power switch).
Press menu and enter into code 51: Programmable Mix 1, set master to Flap, Slave to Flprn, select the switch that corresponds to your landing flap position (make it a 1) under position 1 make the down value increase to raise the ailerons when landing flap is selected.
Don Perry 10-18-2011 07:57 AM
KC36330,
Thanks for your help!!
I had it programmed in less than 5 min.
Thanks chad for your response also.
Don
KC36330 10-18-2011 09:55 AM
You're welcome!!
