RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Do you Don't you 2 (https://www.rcuniverse.com/forum/rc-jets-120/10884470-do-you-dont-you-2-a.html)
bigplumbs 12-31-2011 08:49 AM
Do you Don't you 2
Do you bother to ballance your 2 cell ECU Lipo when you charge it</p>
Wayne22 12-31-2011 11:20 AM
RE: Do you Don't you 2
At the field, no..
At home with my super duper balancing charger - yes ....Although I have never seen more than a .01 Volt difference between the cells even if they were not balanced...
Dr Honda 12-31-2011 12:20 PM
Every few charges... I plug in a blinky. I don't like the balance charge on most chargers.
Boomerang1 12-31-2011 03:46 PM
What Wayne22 said. - John.
bigplumbs 12-31-2011 05:10 PM
ORIGINAL: Wayne22
At the field, no..
That sort of voltage difference is what I also saw for 2 or so years and thought that aint much why bover
Steve Moore 01-01-2012 02:31 AM
How often do you guys cycle your 2s lipos?
bigplumbs 01-01-2012 03:01 AM
ORIGINAL: Steve Moore
Cycle. I dont think you should cycle them. They should never drop below 3 volts per cell
Vettster 01-01-2012 07:33 AM
If you want them to last a very long time...They should never drop below 3.8 per cell. 3.1 is the absolute bare min.
flyinfool1 01-01-2012 07:39 AM
As far as the poll, I voted sometimes.
At the field it depends on which charger I have with me. If I also brought electric powered aircraft to the field then I will have my big fancy charger with me, my small charger that lives in my jet flight box does not have balance capability.
At home I always balance charge.
I still have some good LiPos that are so old, they do not have balance plugs on them.
I cycle all LiPos when new and write the capacity on the pack for future reference.
I cycle all of my LiPos regardless of size or cell count at the beginning of each flying season just to measure the capacity to see if they need replacing or not. I replace them when the capacity drops to 90% of new.
If I have anything that may be a power issue, cycling is the very first test to be sure that the source of power is good.
Sooooooo.......... I guess that I do cycle my LiPos.
My balance charger has a LiPo discharge function that can monitor the voltage of each individual cell and it ends the discharge cycle when the first cell drops under 3.2V
BaldEagel 01-01-2012 09:07 AM
What has not been addressed is Kero start on LiPo, if your two cell LiPo has a high discharge rate the likelyhood of the cells getting out of ballance is increased and therefore ballancing becomes more of an issue, hence the increasing use of LiFe in jets.
Mike
Jame 01-01-2012 11:52 AM
Thats something new for me, I'd assumed because there was more than a single cell present, a Balance charge was always needed, everyday is a school day :) Ive always balanced charge all LiPo batteries, not had any problems so far, although I do only use them for Rx / ECU Power in my Jets and Helicopters.
Regards
Jame
