Crow Setup
I was trying to find the youtube video on setting up Crow on my 12X. It seems to have vanished.
RE: Crow Setup
RE: Crow Setup
Wow that is so complicated, I just select Flapperons and go from there.
Mike |
RE: Crow Setup
There is a glitch in the 12X if you have the hybrid version. Switching back and forth between PCM and 2.4 it loses part of the programming. For programming crow set wingtype to normal with dual aileron. mix flap to flaperon
RE: Crow Setup
Thank you so much Bob
I have been looking for this for too long. Im grateful to RCUniverse also for such an amazing way to share information. :) :) |
RE: Crow Setup
Well, its so easy the way Dustin talks you through this. And since i have been flying this plane for a while, i already had the flaps, and delays on the flap function. . .. So all i had to do was Mix Ret to Flapperon, and dial in 60%, and thats all i had to do. The rest is for the flap and delays. So to re-emphasize, there is very little to do.
So thanks Dustin, and thanks again Bob John |
RE: Crow Setup
You're welcome. Glad I was able to help.
| All times are GMT -8. The time now is 01:31 AM. |
