RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Ziroli F4?? (https://www.rcuniverse.com/forum/rc-jets-120/11004-ziroli-f4.html)
hmx 12-31-2002 12:12 PM
Ziroli F4??
Anyone out there build or flown one??
Wingspan is about 35"
Weight is stated at 4 to 5 lbs.
Just received partially built plane and need help/info!
Thanks!!
Happy New Year!!
JustFly 04-22-2003 06:43 PM
Ziroli F4??
I built one a few years ago. It's a neat looking plane but I was never able to get mine airborne. Mine weighed about 5.25 lbs. and had the Kress Fan with a 7.5 K&B in it. When I was building mine I noticed an error between the plans and the instructions in regards to the incidence on the stabilizer. The instructions called for one incidence and the plans called for a different amount. I used the amount on the plans which was less than the instructions. Kress claims well over 6 lbs. of thrust at 22,000 RPMs which on 35% nitro I was able to acheive. If I were you I would contact Zeroli and ask them about it. Good Luck.
