RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   VELOX (https://www.rcuniverse.com/forum/rc-jets-120/11060572-velox.html)
JAMES SMITH 04-28-2012 04:27 PM
VELOX
i NEED THE FOLLOWING INFORMATIO ON THE VELOX
total elevator throw
additional up elevator with the flaps down
I am using 35mm down flap,is this enough flap?
thank you
james smith
Sparhawk 04-28-2012 08:50 PM
RE: VELOX
From Sandor's build manual:
<span style="color: #0000ff">Sandor,s Velox (Velox Nr 1 Prototype)</span></p>
<span style="color: #0000ff">Rudders 20mm-20mm
Look out on inside that the rudders never get caught by elevator.</span></p>
Ailerons Up 30mm - down25mm Expo 40% (very fast response Dual rate preferred to 80%)</span></p>
<span style="color: #0000ff">Elevator Up 25mm-Down 20mm 25% expo
Slow speed &amp; landing 30mmup 20 mm down.(elevators)</span></p>
<span style="color: #0000ff">Flaps (need work must be slower to land-as we need more flaps) Flaps down 30mm need
elevator to raise up by 15mm together If you use a JR radio it needs on a linear mix 61% for
mixing..</span></p>
<span style="color: #0000ff">C of G
This is how we fly it:
Exactly on the front tube (10mm one)
Slightly nose down!
Build it
</span>Idon't think he'llmind me posting it...
Dan</p>
JAMES SMITH 04-30-2012 10:37 AM
RE: VELOX
Sparkhawk
thank you for the volex throws.
james smith
