RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   DX18 and telemetry with jetcat....? (https://www.rcuniverse.com/forum/rc-jets-120/11181069-dx18-telemetry-jetcat.html)
kirkj 08-04-2012 04:20 PM
just downloaded the new DX18 airware, which says it now supports jetcat data with the telemetry ;)
i would love to install the TM1000 in a new build, if i can access the jetcat data along with rx data and batt voltage.
dont see a jetcat cable on the web site.... ??
cessna172av 08-04-2012 05:27 PM
RE: DX18 and telemetry with jetcat....?
I was looking for it and I only found them on German websites
Here is the s/n for the jetcat telemetry module from spectrum hope you can fine one state side
spma9584
Owen<br type="_moz" />
kirkj 08-04-2012 05:37 PM
i dont see that number anywhere on hte horizon site or spektrum site, but as you said it appears in the EU at online shops. ??
cessna172av 08-04-2012 05:47 PM
If you put it in your search engine like google you should find it
DavidR 08-05-2012 07:45 AM
Kirk,
Chris Huhn was using it on his Ultra Bandit at Winamac, I'm pretty sure his was still a developmental version since he is one of the Spektrum managers at Horizon. You might give him a call.
DR
Greg Wright 08-05-2012 12:14 PM
Kirk,
I was just out flying with Chris Huhn yesterday and i believe that you will start seeing the Jet Cat telemetry stuff start to show up in the HH OR Spectrum web sites soon. As they just did the recent up date for the DX18 radio as of yesterday. Like DavidR has said i'm sure they wanted to make sure everything worked perfectly in the development stages before they released any product. Chris also said that with this recent up date you should be seeing much better Counts on your data logger after a flight which we did see on chris's ultra bandit yesterday after he did a flight with the update installed in his radio.
Selleri 08-07-2012 01:35 AM
[link=http://www.horizonhobby.com/pdf/SPM_Telemetry_Compatibility.pdf]http://www.horizonhobby.com/pdf/SPM_Telemetry_Compatibility.pdf[/link]
turbine guy 10-03-2012 10:58 AM
Now available at "Phil's hobby shop" on eBay "buy now" about $45
kirkj 10-03-2012 11:01 AM
ORIGINAL: turbine guy
Now available at ''Phil's hobby shop'' on eBay ''buy now'' about $45
I have been using it for about 2 months, it works great. Horizon is always on the cutting edge.
DominicM 10-03-2012 11:12 AM
http://www.spektrumrc.com/Products/S...rodId=SPMA9584
When operational, the JetCat sensor will measure:
throttle position,
pack voltage,
pump voltage,
EGT,
RPM, and
OFF condition.
schroedm 10-03-2012 12:20 PM
Can you set alarms against each parameter to alert you of some sort of issue?
lov2flyrc 10-03-2012 12:39 PM
We have them on order, stock expected to arrive on Monday.....
Carbon-Customs 10-03-2012 01:32 PM
what about something usefull like... hmmm remaining fuel???
CraigG 10-03-2012 02:05 PM
ORIGINAL: Carbon-Customs
It's worth it just for the rpm's. Nice to know that engine is running when you can't hear it.
Carbon-Customs 10-03-2012 02:16 PM
ok well... i cant see the point before we know how much fuel we have left, remember we fly jetcats, they dont flame out :)
Tom Antlfinger 10-03-2012 06:19 PM
In stock at Horizon for $39.95.........I added a GPS sensor for Ground Speed in addition to Airspeed
Sensor I have already installed in my UB.........that qualifies them for free shipping UPS ground......
Alarms are user selectable......
TA
Quandry 01-10-2013 03:31 AM
Overview
The Spektrum™ SPMA9584 Aircraft Telemetry JetCat sensor is compatible with the Spektrum TM1000 Telemetry Module X-BUS expansion port.
Specifications
Type: SPMA9584 Aircraft Telemetry JetCat Sensor
Measures: Throttle position, pack voltage, pump voltage, EGT, RPM, OFF condition
Operational Voltage: 3.5 to 9.6 volts
Dimensions: 28mm x 16mm x 7mm
Weight: Circuit board - 4 gram
Calibration: No user calibration required
Units: Metric or English units
Includes:
Sensor
6-inch X-BUS extension
Key Features
Displays key turbine data including Turbine RPM, Turbine temperature, Throttle %, ECU Pack and Pump Voltage, and ECU status
Easy installation and use. Simply Plug in Jetcat sensor to ECU and TR1000 telemetry module
User defined vibration and/or tone warnings alerts users if an issue with the turbine occurs in flight
Source: http://www.spektrumrc.com/Products/D...rodID=SPMA9584
I picked one of these beauties up the other week...
Very small and very light
http://rcparkflying.com/rcpf/telemetry/IMG_5278.JPG
This is what comes in the packet
http://www.rcparkflying.com/rcpf/telemetry/IMG_5276.JPG
I found it worked well connecting to both my DX18 and iPad w STi
http://rcparkflying.com/rcpf/telemetry/IMG_5288.JPG
A couple more pics and description here:
http://www.rcparkflying.com/radio-co...ensor-spma9584
Anyone else using the JetCat sensor and how do you find it?
corndog2 01-10-2013 03:53 AM
The most important thing I think is fuel usage but it doesnt seem to do that. Nice none the less
tulz161 01-10-2013 08:22 AM
Quandry - No problem to have the sti and ipad connected to the same telemetry tx as the dx18?
dubd 01-10-2013 09:11 AM
Can two sensors be adapted for twin engine applications?
Quandry 01-10-2013 11:38 AM
ORIGINAL: corndog2
Yes that would be a very nice addition, however to be able to see the running condition while flying and be able to alert on unusual conditions is also pretty useful, maybe with some time and effort it would be possible to create an alert about a flame out condition, possibly based on RPM or EGT? Note also that the STi app allows for data logging, so it is possible then to correlate flight data against GPS data - adding in the G sensors would also create some interesting stats to look at.
ORIGINAL: tulz161
Yes it's no problem at all, the bind procedure is to connect the STi to the ipad and start the app, power on the RX (while holding down the bind button on the TM1000), then click the bind button on the iPad app, finally enter bind mode on the TX and it all syncs up. Be wary of binding on carbon or steel reflective surfaces, and if it doesn't work at first then try with the TXheld a little distance away (1 or 2 metres). I've found the process to be very reliable. The only part that is tricky is that the bind button on the TM1000 is recessed and very small, you need a tooth pick to actuate it so sometimes a second pair of hands helps depending on where it's mounted in the model.
ORIGINAL: dubd
I don't know for sure but my gut reaction is no, I didn't notice anything in the config which would allow for engine 1, engine 2 etc however I could be wrong. Would be a very interesting functionality to see in place so even if it's not there now it may be on the way in a future release?
dubd 01-10-2013 11:57 AM
Manual mentions daisy chaining sensors, so it gives the impression that multiple can be used.
Quandry 01-10-2013 01:13 PM
ORIGINAL: dubd
You can see in this picture Ihave the GPS sensor daisy chained to the JetCat sensor so I tend to agree with you that daisychain would work, although I'm not sure if the software has the logic enabled for running two of the same sensor and showing seperate sets (two columns) of data?
http://rcparkflying.com/rcpf/telemetry/IMG_5279.JPG
http://rcparkflying.com/rcpf/telemetry/IMG_5285.JPG
dubd 01-10-2013 01:17 PM
I was hoping to daisy chain two jetcat sensors, not share one.
