RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   big scale? (https://www.rcuniverse.com/forum/rc-jets-120/11251280-big-scale.html)
mongo 10-04-2012 05:52 PM
big scale?
http://www.rcuniverse.com/forum/m_11250612/tm.htm
my kinda scale model.
wonder how much it will run us?
jetpilot 10-04-2012 06:41 PM
RE: big scale?
I guess they used Futaba since it didnt matter if it crashed. :-)
STKNRUD 10-04-2012 06:51 PM
RE: big scale?
From the clips I've seen, it looks like they had AA mechanics do the seat installations. ;)
Springbok Flyer 10-04-2012 07:15 PM
RE: big scale?
Yes they specifically chose to use Futaba - it was the only way that during this deliberate crash, they could be sure it was due to pilot input only..... :-)
jetpilot 10-04-2012 07:37 PM
RE: big scale?
ORIGINAL: Springbok Flyer
LMAO!!
GSR 10-04-2012 08:19 PM
RE: big scale?
FAA did it about 25 years ago with a 707. They were mainly testing a a fuel additive to resist burning. Didnt work big time. They also had a whole bunch of crash test dummies in it. Scotty
MajorTomski 10-05-2012 04:40 AM
RE: big scale?
ORIGINAL: GSR
Well, first it was a 720. The airplane entered a dutch roll just before touch down and skewed the results of the test, in that the plane didn't hit some cutting structures planted on the ground squarely. These were supposed to cut the wing skins but ended up slicing the hot engines wide open. The fuel additive did work as advertised, the acutal flame temperatures were much lower than those seen in an untreated JET "A" fuel fire.
An odd side note the ACLU actually sued the FAA over the placement of the crash dummies. The dummies were delivered in two batches. The FAAers just started loading them front to back in the plane as they arrived. As it worked out all the dark skinned dummies were in the back of the plane. The suit was brought to make the distribution of light skinned and dark skinned dumies uniform throughout the cabin. Ironically this was the test that revealed you have a much higher probability of surviving in the tail.
I was the Safety Officer for the C/KC-135 fleet when this test was performed and followed it very closely.
