Cheap rivets
1 Attachment(s)
HI Guys, thought I"d share a effective and cheap way to apply rivets.
Today I am applying rivets to a repaired wing, before I apply the primer. The bit is home made from a broken dremel bit, you can made any size rivet by the angle of the bit. Rcpete |
RE: Cheap rivets
Looking good Pete. Is that the T-33?
RE: Cheap rivets
1 Attachment(s)
HI, yes the T-33
Rcpete |
RE: Cheap rivets
Looking good Pete...;)
RE: Cheap rivets
Great technique, looks easier & safer than burning. I'll have to try it. Thanks for posting Pete!
RE: Cheap rivets
Yeah, nice job, I remember reading years ago that you do the same job using piece of brass tubing, and sharpening the part you are going to use as the tip, and with this method you can use different size tubing to match the size of your model, HTH.
RE: Cheap rivets
Pete, I imagine you haveto be careful wen you do that type of riviting. I equate it to perforated paper....rrrrriiiiiiiipppppppp[:@]
RE: Cheap rivets
HI, I can not take credit for the rivets, I picked up the procedure from the best in the world, Graeme Mears.
Rcpete |
RE: Cheap rivets
Hi Peter........ Graeme is looking over my shoulder and saying thanks for the compliment
| All times are GMT -8. The time now is 03:46 AM. |
