JetCat P-90RXi details
1 Attachment(s)
Had a chance today to look closely at one of the P-90RXis that came in.
Nice detail as always. Compact unit and the box looks empty! Dw |
RE: JetCat P-90RXi details
I have one on order. Bob W. says they will be here Jan 2nd. Merry Christmas!!!
can you post a pic with the front cover off? I'd love to see how they crammed it all in there. That probably took more engineering than the rest of the engine !!!!
Wilcox told me that the one they sent to Him, he had someone flying it. And that he has had ZERO problems with it. Just what I was told.
Pump and Ecu are inside the cover! Amazing, just the battery is oustside, the only conection is the power cord?
And Your fuel source...
Come on Dave, show us what's under the hood...!:D
ORIGINAL: megafly Pump and Ecu are inside the cover! Amazing, just the battery is oustside, the only conection is the power cord? |
What's the thrust? 20 pounds?
I keep wondering why people want all the stuff under the hood so to speak
ORIGINAL: corndog2 I keep wondering why people want all the stuff under the hood so to speak |
ORIGINAL: ianober ORIGINAL: corndog2 I keep wondering why people want all the stuff under the hood so to speak |
Didn't see this till home and away from turbines!
They chopped the corner of the fuel pump off and bolted it in :) Power is around 22-23lb I like the valves being under cover, not so sure about the pump, more weight behind the balance point! Long line from the tank to turbine possibly means the header should be mounted nearer the turbine (been meaning to ask JC what the max length of 4mm tube can be...or run 6mm nearly all the way, then step down to 4mm just before the turbine... Its driven by peoples need for simplicity, certainly some airframes it will work great. I may stick one on my BVM BobCat Composite, its a bit nose heavy anyway and installation will be super simple! Dw |
The Rx 140 and 180 you can just unplug and change the valves (new valves have mounting holes in a new orientation)
I guess this is the same Dave |
ORIGINAL: ianober ORIGINAL: corndog2 I keep wondering why people want all the stuff under the hood so to speak Joe |
Hi, Dave
The JetCat P-90RXi is 25lb of thrust, it is 3lb more than the P-100 RX. Regards Mike |
So how much thrust is this engine I see some say 22lbs and other 25lbs what the official number.. I looked on jet cat USA website and it didn't even mention the p90
It's new lil buddy, wait for it! 25lbs
According to the Jetcat (Germany) werbsite the P-90 is rated at 105N, which is 23.6 pounds.
Joe |
Ok, it's 23.6 lbs Joseph. Thanks Joe!
I'm the one who got the P-90RXi from Bob wilcox and it was tested over and over
and is a true solid 25lb turbine. I have it in JL viper jet from Global Jetclub. Regards Mike |
No you see jimmy it's 25lbs of thrust... ughhh your whats wrong with these forums
So much mis information running around out there now! :):D |
Ok, it's 25lbs like I told you Joseph! I told you so, I told you so! Thanks Mike! No thanks Joe!
I have been waiting on th jetcat p90 rxi for quite a while but a bit disappointed at what i am hearing about the thrust and now with the pump under the hood . I have my flash ready waiting for a power plant . I was looking at the kingteck 140g , does any one have one in a uf and how is the perforamance and reliability and can one of you experienced guys out there please do me a favour and pm me a recommendation. I already have p80se but because of the kero plug it makes for difficult installiation , the wing touches it and i do not want to modify the wing . PLEASE i am not looking for brand bashing or negative comments , i would like some serious and honest input .
thanks |
