RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Air Gauges (https://www.rcuniverse.com/forum/rc-jets-120/11340778-air-gauges.html)
Don Reger 12-22-2012 01:27 PM
Air Gauges
Bought some air gauges from McMaster-Carr. I am looking for an adopter for the back side so I can use them in a jet? I have some but in a different jet. I do not remember where I got the adopter.
Wclays 12-22-2012 01:34 PM
RE: Air Gauges
Which gauges did you get?
Don Reger 12-22-2012 01:43 PM
RE: Air Gauges
Miniature, has a NPT male Connection
k12rc 12-22-2012 01:54 PM
RE: Air Gauges
try www.clippard.com/ they have small fittings
Wclays 12-22-2012 01:59 PM
RE: Air Gauges
http://www.mcmaster.com/#5346K81
What about these
Flynstuff 12-22-2012 03:02 PM
RE: Air Gauges
Don
Can you post the link for the gauges?
Wclays 12-22-2012 04:27 PM
RE: Air Gauges
I think these are the ones.
http://www.mcmaster.com/#atmospheric...gauges/=kpjfrt
john4648 12-22-2012 04:38 PM
RE: Air Gauges
Don got the McMaster #38105K51 gauge so needs an adapter from std airline to a 1/8" NPT
Thanks for the help
John
Miniature Gauges
Use with air, water, hydraulic oil, ethyl alcohol, natural gas, and nitrogen
Pipe Connection: Brass NPT male or brass BSPT male
Accuracy: ±5% full scale (Grade D)
With a dial that’s less than an inch in diameter, these gauges work well in tight spots. Case is ABS plastic and lens is impact-resistant polycarbonate. Temperature range is -40° to 150° F.
Available Pressure Ranges (psi)
Pressure
Range Grad.
Marks Numeric
Increments
0-160 10 40
To Order: Please specify pressure range from the chart.
Center Back Connection
NPT Male
Dial Size Pipe Each
29/32" 1/8 38105K51 $9.92
k12rc 12-22-2012 05:14 PM
RE: Air Gauges
38105K51
11924-1-PKG
( In Stock )
Packages (10 ea.)
Qty:
11924-1-PKG
View 3D Model
check this one out at clippard
rhklenke 12-23-2012 05:26 AM
RE: Air Gauges
I tried those gauges and the problem is, after you add the adapter, they are not only big, but heavy too - and they don't really save you many $'s over the ones you can get from Dreamworks...
Bob
Dr Honda 12-23-2012 05:54 AM
RE: Air Gauges
ORIGINAL: rhklenke
Bob
Yep... What he said. Besides.... 1/8" barbed fittings are too big. You need 1/16" for air hose.
k12rc 12-23-2012 06:35 AM
RE: Air Gauges
They have the 1/16 if that is what he needs i agree about the weight I use the digital fron dreamworks
Don Reger 12-23-2012 08:13 AM
RE: Air Gauges
The weight does not bother me. I can see the larger ones better. Thanks for the help on the adopters.
dadragon 12-23-2012 08:15 AM
RE: Air Gauges
Sierra carries a 160lb guage with the nut and air nipple built in 7/8 dia. if I read it rite they are 2 for 20.00.
Wclays 12-23-2012 04:11 PM
RE: Air Gauges
Do you have a web site for Sierra?
Harley Condra 12-23-2012 05:10 PM
RE: Air Gauges
Try this....Google makes it very easy.
http://www.sierragiant.com/prod01.html
smchale 12-23-2012 05:48 PM
RE: Air Gauges
ORIGINAL: dadragon
I read it as $20 each if you buy two, or more.
rick hamel 12-23-2012 07:20 PM
RE: Air Gauges
I have always soldered small brass tubing into the bore and then soldered a barb on the end of the tubingthen the airline goes right on
cmjets 12-23-2012 11:45 PM
RE: Air Gauges
1 Attachment(s)
Hello::)
I use this FESTO, for less 20$.
BR from Spain.;)
Carlos Márquez
_____________________________________
http://cmjets.blogspot.com.es/
smchale 12-24-2012 05:28 AM
RE: Air Gauges
Has anyone come across a more compact (smaller face) gauge than the 29/32" dia ones we typically use?
The smallest I've found is here: http://www.miniaturepressuregauge.com/
I inquired about getting them in a rear mount and they came back with the following notes:
For steam driven models we only manufacture these in bottom connection
½” ranges: 0-80psi, 0-100psi & 0-120psi
If you want 0-150 psi, you will need to have ¾” or 1” diameter pressure gauges
1/2" Pressure gauge for steam driven models,
Supplied with nut & tail piece.
Price: 10 off @ 20.00 each or 1-9 @ £24.00 ech
3/4" Pressure gauge for steam driven models, reading 0-150psi,
Price: 1 x 9 off @ £20.00 each
Price: (Pounds Sterling)
Delivery: 10 days
Wondering if there are other options out there in a similar size?
RSO 12-24-2012 10:18 AM
RE: Air Gauges
Don: Ron, Lance, & I have the same gauges, and have had good luck with this push on style connector for years. Works great with BVM air tubing. I think this is the correct order number, but double check the sizes.
McMasters catalogue page 186, part #5779K123.
Jerry
Don Reger 12-24-2012 04:11 PM
RE: Air Gauges
Thanks Jerry, I ordered 2 to try.
