RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Jetcat 180RX Sputtering..... Why? (https://www.rcuniverse.com/forum/rc-jets-120/11409196-jetcat-180rx-sputtering-why.html)
Rush! 02-13-2013 10:22 PM
We have a 180RX that was just run, NIB, and all went well...... well except for the weird sputtering/flaming at idle. It seems like its getting little surges of fuel during the idle causing it to sputter and flame a bit.
Any ideas what could be causing it? Havn't changed any of the ECU paramaters. Could this potentially flame out in the middle of flying?
Thanks guys!
Regards<br type="_moz" />
DiscoWings 02-13-2013 10:35 PM
RE: Jetcat 180RX Sputtering..... Why?
post in jetcat forum, i had issues like this too and it was a fuel pump and solenoid problem.
Rush! 02-13-2013 10:42 PM
Thanks Discowings...
leopaul 02-14-2013 05:03 PM
Normally this is caused by excess lube. The excess
fuel make a drop that make a popping noise when it burn!
Rush! 02-14-2013 06:18 PM
Autotune was disabled...  Now enabled....  Duh.....  <div>
</div><div>
</div><div>Thanks guys...  Problem solved</div>
ddennison 02-14-2013 09:32 PM
Where did you figure that out, just looking through the GSU screens?
I have a new one too, have not run it yet though...
Dave
Rush! 02-15-2013 07:18 AM
Yea....  looked at all the settings.  Apparently, the RX series has that option.
mario tavarez14 02-15-2013 11:24 AM
yes i have the same situation with my P-180 RX Sputtering in idle , need some help with that guys
ddennison 02-15-2013 04:01 PM
Are the ECUs not coming programmed correctly?
Rush! 02-15-2013 05:18 PM
They are...  apparently the new ECUs have the option to manually adjust or to use auto tune.
