RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   First inside replaceable burner (https://www.rcuniverse.com/forum/rc-jets-120/11420377-first-inside-replaceable-burner.html)
Santino.G 02-23-2013 01:57 AM
1 Attachment(s)
Specifics :
outside diameter 3,7mm
weight 6 gr
pre-warmer & vaporization time 3 sec
current <4 A
<!4><!4><!4><!4>voltage 6,5 - 7,3V
Santino
http://www.baronerosso.it/forum/atta...0033.jpg?stc=1http://www.baronerosso.it/forum/atta...p;d=1361613249http://www.baronerosso.it/forum/atta...0035.jpg?stc=1
Santino.G 02-23-2013 06:15 AM
RE: First inside replaceable burner
Here follows the video showing the turbine start with this new burner
Select the 1080HD resolution to see the engine parameters
The initial sequence consists of:
1) 0,5 sec to spin up the bendix
2) 1,0 sec to rise up the turbine rpm
3) 0,5 sec to detach the bendix for the bearings condition ECU monitor
4) 2,0 sec to regain the bendix and to rise the rpm at about 5.000
5) ignition
6) as soon as the temperature rise 8&deg; within 2 seconds, the main fuel starts
7) at 150&deg; it starts acceleration to minimum rpm
[youtube]http://www.youtube.com/watch?v=_HuBJeNHP1g&amp;list=HL1361627748[/youtube]
chrigui 02-23-2013 09:33 AM
grande santino!! sei un ARTISTA!!!
Santino.G 02-23-2013 09:54 AM
Grazie Chris, vedo che c'e' molta paura a fare domande!
chrigui 02-24-2013 04:20 AM
forse hanno paura di fottersi il servizio di revisione
