RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   BENCH BUDDY - new idea/accessory (https://www.rcuniverse.com/forum/rc-jets-120/11477703-bench-buddy-new-idea-accessory.html)
marc s 04-14-2013 08:07 AM
1 Attachment(s)
A while back I was doing some work on my jet, I don't have room in the workshop for a bench and a dedicated jet stand so use the workbench top as the place of surgery - problem is making sure the jet is safe and at a height where its easy to work on.
Sure I could use sponge or pillows, carpet or a variety of other 'soft furnishings' but not all are ideal and not all hold the jet from rolling over should it be tilted. I tried one of the low jet stand products, but this made the the jet too high to work on so had a friend cnc an idea I had and this is it - the Bench Buddy ;)
Kinda naff name but it had a tacky ring to it so for now that's what its going to be called.
Essentially it a cnc cut high quality closed cell foam rest, shaped with a shallow curve in the top face to cradle the jet fuselage, in addition to the curve it has a series of holes cut out, these weaken the foam allowing it to further compress where the loads are from the airframe shape resulting in a deeper cradle effect. I mounted the two foam cradles to a cnc cut MDF base, this is shaped to allow the corners of the frame to be fixed with screws to a work top or if needed a wooden carry frame, where the two slots cut at each end would allow a Velcro or strap to be passed down and back up for securing a fuselage to the bench buddy for transport.
The height allows good access when placed on a workbench, but also allows a safety space under the airframe for aerials or vents to remain clear from grounding.
Its a work in progress so comments and ideas on how to improve it are very welcome, depending on the final outcome and cost to manufacture I may look to add it to my shop as an accessory for those interested. My jet is a small 2m span sports jet and it sits nicely in place and when rocked is reluctant to roll over but moves back to its original position when released. It is designed to work with much large jets too.
marcs
sailing1 04-14-2013 08:28 AM
RE: BENCH BUDDY - new idea/accessory
Great idea! I have a home made foam stand sort of like this one that I have used for some time. I wasn't smart enough to mount the foam on the base as you have done so I must be careful not to pull the foam over when I slide the whole thing around. You idea is simple and functional and will be really useful over a wide range of airframes.
JohnMac 04-14-2013 08:30 AM
Great Idea,
Can I suggest you fix some of that anti-slip matting to the bottom.
John
George 04-14-2013 08:31 AM
Marc,
A very cool idea and it looks great. A possible suggestion would be to offer different sizes of foam or perhaps one piece like you have with more of a U-shape on one side that could be "flipped" to give more height if needed.
Just "thinking out loud".
marc s 04-14-2013 08:40 AM
Yes wanted to try to get a 'one size fits all'
John this job might be better done by the user, the tool drawer liner matting is great for this, a few dabs of cyano and job done ;)
George, interesting, and yes bound to be different height needs, the issue is the foam needs to be glued into the base to stop it popping out when you move the jet so might be tricky to cover this but nothing stopping you adding height to the Bench Buddy itself either via feet you can add by screwing them into the holes at each corner or maybe I can make slot in extender legs to give a few height options......
marcs
Robrow 04-14-2013 08:49 AM
Another great idea Mark, would it also work with a wing?
Rob.
marc s 04-14-2013 09:05 AM
Rob yes indeed.
marcs
DrScoles 04-14-2013 09:44 AM
That would be nice in my trailer as well instead of the big foam pieces. Are you produce and sell these? I would take 6 of them :-)
Paul0088 04-14-2013 10:32 AM
looks good I'll take a pair :D
marc s 04-14-2013 10:34 AM
Possibly, will explore costs to make etc, a few tweaks here and there and if a few of you jet guys want some (subject to price naturally) I will make a small batch to see how they go.
marcs
invertmast 04-14-2013 05:18 PM
I could definitely use a few pairs. Some Extra small ones for Hotliner style models would be great as well!
jack744 04-14-2013 06:17 PM
To adjust height could you make some snap on bases with the same or larger foot print and you go higher to stablize the stand kinda like Legos and use the same kind of foam to let them push together. Just a thought on the height issue.
Wayne22 04-15-2013 06:02 AM
brilliant, simple, functional, and adaptable.
I think you have all the bases covered and still give individual owners the freedom to customize it to meet their specific needs. It would be time consuming and diificult trying to create something that would fit 100% of the airframes and 100% of the pilots. You have covered a wide base of needs with this design.......lets get it into production!
DrScoles 04-15-2013 07:35 AM
ORIGINAL: Wayne22
Exactly my thought. I think the one posted is perfect! Please let me know if you are going to sell them!
GR7Racer 04-16-2013 09:50 AM
I'll take a pair!.... Great idea!!
KennyMac
Turbotronic 04-16-2013 11:24 PM
Best original idea Ive seen for a while. <strike>Only thing I would add is a means to strap down the jet, say using stretch and velcro material to double as storage/transport rests.
Would work to transport in van, store on racks etc. So you could move the jet around with the rests attached making it an easy one man job.</strike>
My Euro is resting on pillows on a rack, this would be ideal. Brilliant!
Andre
Ok did not read properly...
marc s 04-17-2013 01:17 AM
1 Attachment(s)
Appreciate the positive feedback guys ;)
OK been thinking about the height thing, the design was initially done so when a jet is placed on a workbench on the Bench Buddy it would remain at a height that allowed access and ease of work, however for those who like the idea of having an option for a degree of height adjustment here is an idea.
If I offer an accessory pack which you can buy separately to the Bench Buddy that contains say 4 x adjustable feet and 4 x special inserts to allow these to fix to each corner of the BB along the lines of the picture attached would that tick boxes? If needed I could also add an option to add castor wheels too so the units could be wheeled around (will need to be a smooth surface to avoid the BB from twisting away from the fuselage) - thoughts?
Hope to have some idea on price in the next day or so too.
marcs
sailing1 04-17-2013 05:32 AM
Just a simple idea. You might offer the Bench Buddy as designed but in a couple of different heights as far as the foam cradle part goes. We could then purchase one set of each height and mix and match them to get different angles. I can see wanting at least two sets of these for bench work and plane transport anyway, so why not a couple or three heights to provide some extra flexibility.
marc s 04-17-2013 05:56 AM
Its possible to make foam inserts in different heights, the issue is they need to be bonded to the base to make sure they are 100% secure, if people are happy to do this and have sets in different heights (bonded to the bases in each case) then that's easy to do - guess I need to see what others think.
Next question would be whats the max height needed?
marcs
schroedm 04-17-2013 06:15 AM
Marc,
Any way the base could me made from 2 parts - an upper and lower and a base of the foam sandwiched between the layers somehow? That way you could add new sized foam blocks.
Or why not use H/D velcro instead of gluing the foam down. Any load that's enough to pull off H/D velcro would likely knock the model off the foam first.....,
Cheers,
mark
jetflyr 04-17-2013 08:34 AM
Marc,
How about just producing the foam sections, two sided as mentioned earlier, and a sketch for the base.
"Industrial" Velcro should secure the foam nicely for its intended use, and allow the user to flip the foam as needed - as well as move it closer together for more usefulness.
An added benefit is postage costs will be far more reasonable.....
Great idea, and I want a set!
Greg
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
