RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Brake Lines (https://www.rcuniverse.com/forum/rc-jets-120/11479139-brake-lines.html)
G4guy 04-15-2013 11:12 AM
Brake Lines
1 Attachment(s)
Hi Guys,
How are you running the brake lines on your Pro-Link Gear? I'm having a little trouble with my EuroSport brake lines, I have the brake nipple rearward of the axle and facing up.
the brake line is getting caught between the strut and wheel when the knee action of the strut is working.
Thanks in advance,
Ron
invertmast 04-15-2013 11:29 AM
RE: the brake lines Brake Lines
Mine route along the backside of the strut so as they scissor, the brake line forms a loop aft of the strut. Since i haven't found a good way of keeping the line attached to the strut, i just use two small zip ties. one on the lower strut and another on the upper strut. So far it has worked well and been reliable
sc0tt 04-15-2013 04:18 PM
1 Attachment(s)
A couple wraps of electrical tape has always worked for me.
stevekott 04-15-2013 04:23 PM
+1 on the back side of the strut. On my Euro then off the back of the strut I go to wing tip side of the retract mechanism. Another option to zip ties is 3/8" strips cut from aluminum foil tape or silver "Trim Tape" from the LHS.
