RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Anyone use these? (https://www.rcuniverse.com/forum/rc-jets-120/114888-anyone-use-these.html)
JohnVH 04-24-2002 01:41 AM
Anyone use these?
Sure make mounting a servo EASY
http://www.hobby-lobby.com/images/ra200.gif
jcarl 04-24-2002 02:12 AM
Anyone use these?
Where do you get them and what do they cost?
JohnVH 04-24-2002 02:15 AM
Anyone use these?
from hobby lobby, and around $7 a pair, they are very strong and I am using them for aileron/elevators, and rudders also, they make them in two sizes for standard and small
EASYTIGER 04-24-2002 03:09 AM
Anyone use these?
I got the same ones from Dymond Modelsport for about half the price. Love them.
On a foam wing, you can just drill four holes, glue in four dowels, sand off the tops drill some holes into the dowels for the mounting screws and off you go. These things are GREAT.
Helijet 04-24-2002 03:28 AM
Anyone use these?
John
I have used the mounts for a couple of years now after being introduced to them by Jeremy Ferguson ( Pattern guy ). On some servos however, ( ie JR ) there is a small reinforcement flange in the middle of the mounting lugs. Be sure to file them down so that the lug is evenly tightened down otherwise the servo can rock side to side as the only contact point would be that narrow reinforcement strip. You don't want any servo body movement on the control surfaces. Otherwise works great, makes installations a snap!
Dean
JohnVH 04-24-2002 03:42 AM
Anyone use these?
Great to hear! I am in the process of mounting up, and I did notice the flange Dean, Thanks!
