FEJ BAe Hawk 1:4,5 -CG
...here are some pictures of our new fej hawk cockpit - lot of work but looks good :) - can anybody tell us the best CG for flying? -thanks a lot. best regards from germany
https://lh3.googleusercontent.com/-U...80971300_n.jpg https://lh5.googleusercontent.com/-Z...01646284_n.jpg https://lh4.googleusercontent.com/-9...78866322_n.jpg https://lh6.googleusercontent.com/-E...521_224747.jpg |
RE: FEJ BAe Hawk 1:4,5 -CG
wow that cockpit looks nice where did you get it and how much?
Stunning work on that Cockpit.
My centre of gravity test for the hawk is to have it assembled with no fuel but hopper full. Tilt it so the nose wheel is off the floor and the rear ventral fins are just touching the ground. Release the rudder and the nose should drop down to the ground nice and gently. This is a safe setting, you can fine tune from there. I have flown with Hawks where when I do this test the back stays on the ground but I found it too sensitive on the elevator. If the nose falls to the ground hard, I found it a little nose heavy, which was not too much of a problem with the Hawk, it just means a slightly faster landing speed. I hope this helps? Regards Al |
nice work
ORIGINAL: Ali Stunning work on that Cockpit. My centre of gravity test for the hawk is to have it assembled with no fuel but hopper full. Tilt it so the nose wheel is off the floor and the rear ventral fins are just touching the ground. Release the rudder and the nose should drop down to the ground nice and gently. This is a safe setting, you can fine tune from there. I have flown with Hawks where when I do this test the back stays on the ground but I found it too sensitive on the elevator. If the nose falls to the ground hard, I found it a little nose heavy, which was not too much of a problem with the Hawk, it just means a slightly faster landing speed. I hope this helps? Regards Al What Ali is saying is a great way but this might give you a starting point if you are wanting a measurement. Rex |
thank you guys - this will help me.
@discoWing - the cockpit is all selfmade. Pilot is from Skymasterjet. |
Absolutely stunning cockpit!!
You should market them :D S |
Love the detailed work! I would buy one:D
ORIGINAL: smaze17 Absolutely stunning cockpit!! You should market them :D S |
