kingtech service
It seems Aeroshell 500 oil is not good for the Kingtech turbines. I sent my 140 turbine back to Dirk (Kingtech service) because it would not spin up when starting; it acted like the bearings were gummy. Dirk got the turbine took it apart found the rear bearing was sticking and gave me a call. They repaired the turbine under warranty and instructed me to stay away from Aeroshell 500 oil. The total down time was about 2 weeks including shipping time. I had the turbine out this Tues and it worked great. It was hot out, about 10,000 ft density alt. The turbine spooled up fast and was a powerhouse as always.
Thanks Dirk and Berry for the great after sale service. George |
RE: kingtech service
George what oil did you switch to?
I recommend the KingTech Special Blend Oil with Shell Tellus 32 & Synthetics
http://www.kingtechturbines.com/stor...products_id=54 This is all i run and have no problems at all..... |
Bob I switched to Kingtech oil for all my turbine's...2 JC, 1Wren, and 3 Kingtech's
| All times are GMT -8. The time now is 11:46 PM. |
