RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Duralite Charging Question (https://www.rcuniverse.com/forum/rc-jets-120/11580296-duralite-charging-question.html)
tp777fo 07-26-2013 07:06 AM
Picked up a Jet Central Rabbit that has a Duralite LiMN battery. It has the yellow "smart charger lead" I dont have any duralite batteries or chargers. How do I charge this thing without making smoke? I use CelPro4 chargers.
Gonzalo38 07-26-2013 07:46 AM
RE: Duralite Charging Question
I used to have one of those batteries. They are 7.4 V and I charge it as a regular 2S Lipo with no problems.
FlyUtah 07-26-2013 08:07 AM
I would find a Duralite brand charger and use that.
I've never heard of anyone using another brand charger for Duralites
-Mark
stevekott 07-26-2013 08:53 AM
Some of those Duralites have built in balancers. Do you charge with two wires or three?
The chemistry on those batteries is Lithium Ion. On my charger it's called a LiLo.
Steve
JJP 07-26-2013 08:55 AM
You can use any lipo charger just set the charge rate below 1 amp if charging through the yellow lead or 1c through the power lead.
BalsaBob 07-26-2013 09:33 AM
I second the response by JPP
Also, I believe that Duralite is phasing out (if they didn't already) their old simple (black box) charger. I think it has been discontinued.
Bob
Gonzalo38 07-26-2013 09:40 AM
When I was charging mine, I just used a normal charger (in my case a Team Orion Advantage Touch charger). Always used the power lead.
With my Duralite Li Ion batteries, I also use the same charger or the Fromeco chargers (Ion Cube and the new Simple Charger 3 channel). No problems.
kev-o 07-29-2013 05:33 PM
If you are in need of a genuine Duralite charger I have 3 nib ones pm or email me [email protected]
Kevin
Gonzalo38 07-29-2013 05:43 PM
Don't use the duralite charger for that battery. That charger is made to be used with duralite Li-Ion batteries that include a balancer/regulator. Any other batteries shouldn't be charged with that charger.
kev-o 07-29-2013 05:53 PM
If its a Duralite battery and has a yellow lead it has the charge safe circuitry in it. I still use them on my a123s and lions and limn packs with no issues at all.
Kevin
highhorse 07-29-2013 05:55 PM
ORIGINAL: Gonzalo38
U misread the OP. His battery IS compatible.
sysiek 07-29-2013 08:34 PM
If the ion the must be charged at 7.2 for two cels or 3.6 one cell ,usually all charges have 3 settings # for lipo 3.7v per cell #2 ion 3.2v per and #3 for life or A-123 3.3 per cell ,do not charge ion is lipo this will over charge the batteries by 0.1v and make the batteries live a lot shorter and the battery will discharge a lot faster it's not the same chemistry than lipo battery .
