RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   DX18 sequencer programming help needed (https://www.rcuniverse.com/forum/rc-jets-120/11587867-dx18-sequencer-programming-help-needed.html)
leopaul 10-06-2013 04:31 AM
I spend the whole evening yesterday trying to program the gear /door sequencer of my DX18 and it seems to be impossible to have it working the way i need.
I use the gear/brake valve all in one.So i usually program a switch that will mix 10% overtravel on the valve to activate the brake.
The problem is when you use the sequencer , the output got renamed as door and wheel and we could not do any mixes on thoose channel....So how i could activate my brake now??
If someone had some idea please, explain!!!
Thanks!!
Dr Honda 10-06-2013 07:05 AM
If your double valve is on a single channel... it's not going to work.
The sequencer has control, and doesn't understand that the single channel can do more than one operation. Think about it... if allowed a double use, and someone messed up a mix... you could quickly over-extend a manual valve, or servo driven gear door.
The only way I could think about making it work... is if there is a way of stopping the sequence until another condition is met. (ie a switch)
leopaul 10-06-2013 04:55 PM
Yes, my double way is on a single channel....
wfield0455 10-07-2013 05:15 AM
Have you tried something like the following: For this example, assume that the gear is on X+2 and that to operate your gear via the sequencer requires a mix such as GER->X+2.
Add a normal mix of RKn -> X+2 (or gear / brake control channel) with a rate of say 30%, 0% and Offset: 0 activated by your Gear switch being in the gear down position.
With the right knob set to brakes off, the gear channel should operate normally and you should be able to adjust the knob to over drive the gear channel and activate your brakes. Depending on the polarity of your gear channel and how much you need to overdrive things you may need to change the rate from 30%,0% to 0%,30% or perhaps even use negate rate values but by looking at the servo monitor it should be easy to sort out from there. Hopefully this helps.
If it could cause problems to have the sequencer cycle the gear if you had left the brake knob active you MAY be able to make the gear sequencer mix activated by a Combo Switch so that the gear will only extend if the gear switch is in the down position AND the brake control is off. If some of this doesn't make sense it may be because I've never seen a setup like you are describing. I'm just trying to offer what I know about DX18 mixes to help solve the problem to the best of my understanding.
