Fuselage molded "exits"??
Guys
I'm struggling to find the right word but basically I'm sure I've seen some neat molded items that you can use to route wires/aerials out of a fuselage neatly in an aerodynamic manner. Think they've be used on full carbon gliders etc to expose aerials to better RF. Does anyone know where I could find some?? cheers Mark |
I thought that Sullivan products makes one, but in looking for it, I found this:
http://www.espritmodel.com/antenna-2...xit-guide.aspx and this: http://www3.towerhobbies.com/cgi-bin...&I=LXE973&P=ML and this: http://www.horizonhobby.com/products...-keeper-DUB349 Bob |
Bob, thanks!!!!!
Has it been proven that a carbon fuselage reduces 2.4 RF quality when using solid systems such as FASST?? Or is it a myth that people worry about?? M |
My manual for the radio says to try and expose them on carbon fiber fuselages.
Originally Posted by schroedm
(Post 11731141)
Bob, thanks!!!!!
(Post 11731141)
Bob, thanks!!!!!
Has it been proven that a carbon fuselage reduces 2.4 RF quality when using solid systems such as FASST?? Or is it a myth that people worry about?? M I had a problem with the FASST receiver in my Exteme Jets F-4 in that as originally installed, I got shorter range during a ground range check than I was used to. It was still more than the 30' that Futaba recommends, but I was used to getting over a 100', and this was significantly less than that, so I was not happy. The receiver was right under the canopy/cockpit, so I put a plastic tube inside the canopy right next to the corner of the instrument panel and the side of the cockpit tube where it was not very visible. After engine start, I take one of the antennas from the RX and put it up the tube when I put the cockpit/canopy on. This fixed the problem and I get lots of ground range during a range check like I am used to, and the link has been flawless in the air. As I recall, there was some carbon in the fuselage layup that I saw before I painted the inside, but when I was building the plane I didn't think it was going to be a problem. On the other hand, there is a lot of electronics and wires around where the RX is, so maybe that caused it. I I was going to do an all-carbon jet with FASST, I'd probably build it up with the antennas inside as normal, but then do a thorough range check to see if there is any effect and have a plan in mind for how to get the antennas outside (or up into the cockpit) to deal with it if it is an issue... Bob |
