x-31
Does anyone know anything about this plane? Is it a manufactured kit or is it just someones scratch built?
http://www.youtube.com/watch?v=NTLZREaRbh0 |
looks scratch built
Its built by a guy called Christian Gobel from Germany. I am not sure if he kitted any, but I do know that his good friend Martin Muller has one and flies the life out of it. Christian contacted not so long ago to tell me that he was selling his X-31 ready to fly.
Regards Al |
Originally Posted by invertmast
(Post 11913564)
looks scratch built
Christian has had two, I saw his first one which I think was red white and blue some years ago. He then not so long ago turned up with the elaborately coloured one as a matching pair with Martin
Originally Posted by Ali
(Post 11913584)
Sometimes your wallet is your best tool.
1 Attachment(s)
Ok guy's,so i have decided to build my own x-31 and here is where i stand on the plug,its about 85% complete.The plane is going to be full 3D with thrust vectoring.What i am looking for is some opinions from the "experts" on an airfoil that i should use.Symmetrical? typical reflex? or some blended type.Let me know what you think.http://www.rcuniverse.com/forum/atta...mentid=2097667
1 Attachment(s)
Sweet! nice project!
And absolutely you will want reflex in this one.. that leds to a nice washout or even curved down wingtips that will help trim the beast and also hold the wings steady at high alpha. The original didnt had reflex at all as it didnt needed pitch up trim as the plane was basically unstable and kept level by the computer... In the model this would not work as well because the cg will need to go forward to get the airplane trimmed in the conventional way. Problem is that the canards doesnt have enough surface area for doing this work properly.. Also due to this cg taking the main landing gear a bit forward would help to make smoother takeoffs and wheelie landings... http://www.rcuniverse.com/forum/atta...mentid=2097721 |
Thanks for your input,reflex seems to be the most common and what I was more than likely going to use.I was really hoping that more people would have chimed in and gave an opinion based on their experience also.
Originally Posted by erbroens
(Post 12042700)
Anytime...some years ago I researched this plane and others while trying to improve my models, learned a lot and also had a lot of fun. You will have also with this plane too. Is a great choice for a jet.
| All times are GMT -8. The time now is 02:35 PM. |
