RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Question on door sequencers (https://www.rcuniverse.com/forum/rc-jets-120/11606501-question-door-sequencers.html)
didiwatt 11-10-2014 11:22 AM
I am looking for a door sequencer for my Comp-Arf Tutor. I have Bohotec C-50 electric retracts. I want the main doors to close while gear down (P-51 style) and the front doors to remain open.
I am using one servo on each main gear door and 2 servos on the front doors (one for each door 1/2). I am using 4 channels right now on the doors.
My Futaba 18MZ does not have the capability to operate the doors P-51 style due to the 9 second delay I need on closing. I have already worked with Bax in the tech dept. and we determined it was not possible and a sequencer will be needed.
All of the sequencers I have located so far will only operate 3 servo's. Using a "Y" on the nose would reduce me to 3 channels but I need different end points so that is not possible.
Does anyone know of a sequencer that would work for me?
Paul
Boomerang1 11-10-2014 11:42 AM
I'm surprised the 18MZ cannot help you out with the sequencing.
I posted some time ago with a sequencing question for the 12FG (a much less sophisticated radio)
& the answers I got solved the problem.
My problems were solved with slowing the retract SWITCH, not the servos, & the point mixing function.
The old fashioned way (mechanical servo arm & linkage adjustment) won't work?
Or spring load them closed & have the noseleg push them open?
I'm working on nosewheel doors for an MB339 at the moment, 4 doors, two cycle closed
when the wheel comes down, two remain open beside the leg. - John.
Jgwright 11-10-2014 12:35 PM
Paul
Paul
have you looked at the Rcbee unit for electric retracts. It allows up to 6 servos.
http://www.rcbee.com/index.php?Page=19
Also check the manual.
John
Jets of Bergen ;-) 11-10-2014 12:41 PM
Hi.
This sequencer handles up to 6 servos , works fine for me :-)
http://www.der-schweighofer.net/product/74430/doorsequzer_projet
Edgar Perez 11-10-2014 01:38 PM
Im using the airpower unit in a Rafale (http://www.dreamworksrc.com/catalog/...tion-Sequencer). Works fine.
Edgar Perez 11-10-2014 01:39 PM
One option is to use hitec servos, for which you can program independent center and end-points.
Rafale Sport 11-10-2014 01:48 PM
Hi, I'm using 3 program mixers in offset mixing mode on the T18MZ for sequencing the electric landing gear and gear doors on a M2000, the start/stop delay duration can be programmed up to 35 sec. On the M2000, the 3 main gear doors close when the gear is down, the 2 small gear doors (servo driven) remain open on the front wheel. I have made a small video of the sequencing programming but unfortunately it is in French...maybe you can have a look and find your way as the software of my T18MZ is in English. The programming of the M2000 sequencing starts at 8:55 on the video:
https://www.youtube.com/watch?v=z5hX6HISJGM
JackD 11-10-2014 02:51 PM
UP2 + UP4 valves.
Only one servo. Ridiculously simple to operate.
Using this setup in my cougar (nose gear doors remain open). No programming needed, UP valves do tge sequencing via backpressure, not time.
This is the first time I use them and Im super impressed with the simplicity
jack
EDIT: Just realized your gear is electric.... so forget what I said
Steve Collins 11-10-2014 03:13 PM
Originally Posted by JackD (Post 11915420)
UP2 + UP4 valves.
jack
I also use Jack's setup in a Cougar. Works Flawlessly and saves channels.
philjac94 11-10-2014 07:11 PM
18MZ can sequence gear and doors, I use it all the time. They just do not have a dedicated sequencing screen yet.
Use this guide, it will give you the idea.
http://downloads.hobbico.com/misc/fu...sequencing.pdf
pkoury 11-10-2014 07:20 PM
I use one of these: http://www.jet-tronics.de/doorsequencer_en.html
number27 11-10-2014 08:27 PM
Use the radio functions of the 18mz even the 14mz can do this. Download the Hobbico files works a treat.
didiwatt 11-11-2014 10:05 AM
Guys, thanks for your help. I see there are several good products available for more than 3 outputs should I chose to use a separate piece of equipment.
I would prefer to use the radio. I tried the hobbico download per philjack94, suggestion and it would not work because because you could not delay the door closing in the gear down mode long enough for electric retracts which are much slower than air. I need 9 seconds.
It looks like Rafael Sport came up with a solution using 3 program mixes. I watched the video and without being able to understand him ( French), I got the general idea.
My Tutor is completely torn down for painting at this time so I cannot play with it. Once painted and put back together I will start another thread and hopefully Rafael Sport will chime in and help me with the programming.
Thanks for all the help.
Paul
number27 11-11-2014 10:19 AM
I have used the Hobbico with electric retracts and doors with Avanti S.
didiwatt 11-11-2014 10:44 AM
OK, I will give it a try when I get it back together. I may have missed something when I tried.
Paul
Bob_B 11-11-2014 11:30 AM
Have a look at this video i made of a sequencer. Watch the time bar and you will see the doors are open for 6 sec before they close again, I could delay them further if needed.
Bob
https://www.youtube.com/watch?v=_CpIFZEjn94
stevekott 11-11-2014 01:46 PM
+3 on giving the 18mz another chance.
I use the Program Mix with the Line Mode. Its just easier for me to see it on the graph rather than the sequencer.
What you are trying to do is well within its capabilities. Good Luck!
philjac94 11-11-2014 02:01 PM
Hi Paul
I also use electric gear and do not have a problem with enough delay. You do not have to follow the Hobbico guide word for word, servo start and travel delays are modified to give you what you need. Use the guide as a starting point only.
I found the guide a long time after my own experimentation with sequencing but have since suggested it to heaps of other interested guys who also use it for electric gear.
It does take a bit of figuring to get right and for a $3k radio it should do it for you.
If you dont have any luck, pm me or call and I can help you along with it. And if that doesnt work I have an old Jetronics sequencer you can have for free.
Phil
didiwatt 11-11-2014 02:21 PM
Phil, will do & thanks
Paul
