Skymaster T-33 build
http://www.rcuniverse.com/forum/atta...mentid=2056802http://www.rcuniverse.com/forum/atta...mentid=2056803http://www.rcuniverse.com/forum/atta...mentid=2056805http://www.rcuniverse.com/forum/atta...mentid=2056806http://www.rcuniverse.com/forum/atta...mentid=2056809http://www.rcuniverse.com/forum/atta...mentid=2056810http://www.rcuniverse.com/forum/atta...mentid=2056806http://www.rcuniverse.com/forum/atta...mentid=2056814Got all my small repairs done, you know, the ones that seam to take forever, cleaned the work table and brought in my long awaited Skymaster T-33 to start the build. Like every project, when the pieces are on the table, you wunder where to start. Looked at it for a hour or so, and whent to town.
This will be the order for now 1- Clean up all,( what not should be their in the first place) 2-remove the speed brakes and tape the flaps for inside red paint. 3-Trim the cockpits for easy removal and install rail for support 4- install the fuel tanks 5-beef up any area's with special epoxy formula of West systems 205 epoxy, milled carbon fiber( very hard to find a supplier) and Cabosil Thixotropic filler. 6-Build a front mount for the gages and power box switch That's 2 days work more to come. Rcpete |
Take some pictures so we can follow along.
16 Attachment(s)
Pics, next is to paint inside area flat black and green on the doors.
Rcpete |
Hi Pete,
I am building my second Skymaster T-33 at the moment. What a great plane ! I have done a building report with a lot of picture here http://www.rc-network.de/forum/showt...Skymaster+T-33 The report is in german but should be no problem if you use a translater. Jens |
6 Attachment(s)
HI all, decided to paint all visable inside flat black, not going to use green.
Rcpetehttp://www.rcuniverse.com/forum/atta...mentid=2057151http://www.rcuniverse.com/forum/atta...mentid=2057152http://www.rcuniverse.com/forum/atta...mentid=2057153http://www.rcuniverse.com/forum/atta...mentid=2057154http://www.rcuniverse.com/forum/atta...mentid=2057155http://www.rcuniverse.com/forum/atta...mentid=2057156 |
2 Attachment(s)
More work done, finished the ailerhttp://www.rcuniverse.com/forum/atta...mentid=2059331http://www.rcuniverse.com/forum/atta...mentid=2059332ons and elevator.
Rcpete |
5 Attachment(s)
Flaps now done, I added a 5ply 5/32'' plate for the horn, their just was not enough thickness to mount by itself.
Rcpetehttp://www.rcuniverse.com/forum/atta...mentid=2059333http://www.rcuniverse.com/forum/atta...mentid=2059334http://www.rcuniverse.com/forum/atta...mentid=2059335http://www.rcuniverse.com/forum/atta...mentid=2059336http://www.rcuniverse.com/forum/atta...mentid=2059337 |
7 Attachment(s)
The Rudder assembly needed extra work, the whole system is too low, into the pipe, removed 3/8'' on the horn /rudder post, also removed the servo plate and replaced it with 5/32'' 5ply, c/w blind nuts for the servo, and raised it a 1/2''. I used just one servo rod, but am not happy with the amp. draw and binding, will remove and go with the suggested pull pull.http://www.rcuniverse.com/forum/atta...mentid=2059339http://www.rcuniverse.com/forum/atta...mentid=2059340http://www.rcuniverse.com/forum/atta...mentid=2059341http://www.rcuniverse.com/forum/atta...mentid=2059342http://www.rcuniverse.com/forum/atta...mentid=2059343http://www.rcuniverse.com/forum/atta...mentid=2059344http://www.rcuniverse.com/forum/atta...mentid=2059345
Pete, have you tried the West Systems 610? It is already a thickend epoxy that is way cheaper then other cartridge dispensed epoxies and it uses a regular caulking gun to pump it out. I use it all the time for filled bonding areas and you could mix in other fillers as well. I don't use the supplied tip and just apply it with a artist's palate knife.
Are you looking for short stranded carbon 1/4 inch or milled carbon like power? I can put you onto the 1/4 carbon but don't know a spouce for the milled powder type like cabosil powder. |
3 Attachment(s)
HI Ron, I have used 610, but I prefer my mix, the milled carbon is hard to find, it is not 200 micron powder or 1/32'', smaller , see pic.
Rcpetehttp://www.rcuniverse.com/forum/atta...mentid=2059406http://www.rcuniverse.com/forum/atta...mentid=2059407http://www.rcuniverse.com/forum/atta...mentid=2059408 |
7 Attachment(s)
More pics
Painted Speed brake and inner flap surface. Jacky Sacks wing bags Wing installed. Rcpetehttp://www.rcuniverse.com/forum/atta...mentid=2059509http://www.rcuniverse.com/forum/atta...mentid=2059510http://www.rcuniverse.com/forum/atta...mentid=2059511http://www.rcuniverse.com/forum/atta...mentid=2059511http://www.rcuniverse.com/forum/atta...mentid=2059512http://www.rcuniverse.com/forum/atta...mentid=2059513http://www.rcuniverse.com/forum/atta...mentid=2059514http://www.rcuniverse.com/forum/atta...mentid=2059515 |
Looks fantastic RCP!!!
7 Attachment(s)
HI, thanks for the nice comments.
Some more progress on the T-33, next I'll start the upper deck with air valves and receiver. Rcpetehttp://www.rcuniverse.com/forum/atta...mentid=2061536http://www.rcuniverse.com/forum/atta...mentid=2061537http://www.rcuniverse.com/forum/atta...mentid=2061538http://www.rcuniverse.com/forum/atta...mentid=2061539http://www.rcuniverse.com/forum/atta...mentid=2061540http://www.rcuniverse.com/forum/atta...mentid=2061541http://www.rcuniverse.com/forum/atta...mentid=2061542 |
2 Attachment(s)
HI, redid the rudder linkage, pull pull, works more good now, smoother and less amp. draw.
Also joined the fuse together. Next, install the pipe and turbine. Rcpetehttp://www.rcuniverse.com/forum/atta...mentid=2061732http://www.rcuniverse.com/forum/atta...mentid=2061733 |
4 Attachment(s)
HI all, installed the turbine and pipe tonight.
Rcpetehttp://www.rcuniverse.com/forum/atta...mentid=2061852http://www.rcuniverse.com/forum/atta...mentid=2061853http://www.rcuniverse.com/forum/atta...mentid=2061854http://www.rcuniverse.com/forum/atta...mentid=2061855 |
4 Attachment(s)
HI all, ran the turbine tonight, started first try, ran like a champ.
Just need to wait now for some gear valves to arrive to finish up, and if my plan is close, should need no nose weight for CG. Rcpetehttp://www.rcuniverse.com/forum/atta...mentid=2062112http://www.rcuniverse.com/forum/atta...mentid=2062113http://www.rcuniverse.com/forum/atta...mentid=2062114http://www.rcuniverse.com/forum/atta...mentid=2062115 |
2 Attachment(s)
All Balanced now, made a battery tray in the nose for the 3 batteries, had to add 1 sq. (1/4 oz.) in the tail for 200mm. CG.http://www.rcuniverse.com/forum/atta...mentid=2065746http://www.rcuniverse.com/forum/atta...mentid=2065747
Beautiful!
Looks great Pete!!
3 Attachment(s)
Thanks Guys, that makes 3 T-33's now, 2 Skymaster and 1 WJM's -FEJ-T-33
Rcpetehttp://www.rcuniverse.com/forum/atta...mentid=2066047http://www.rcuniverse.com/forum/atta...mentid=2066048http://www.rcuniverse.com/forum/atta...mentid=2066049 |
| All times are GMT -8. The time now is 02:03 AM. |
