RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Futaba "Powersafe" 18(?) (https://www.rcuniverse.com/forum/rc-jets-120/11614875-futaba-powersafe-18-a.html)
George 03-19-2015 05:23 PM
Apparently this is in development and/or close to completion (Hopefully)!! http://i615.photobucket.com/albums/t...psec7d2ea9.gif
http://i615.photobucket.com/albums/t...pscbbrqdzb.jpg
3 turn spin 03-19-2015 07:25 PM
Looking for the "like" button. Great idea.
Erik R 03-19-2015 07:32 PM
Excellent news. I lost an Ultra Lightning due to issues with the interface between a Powerbox cockpit Srs, and Futaba sbus Rx's. I have since returned to 6014's, and other power distribution systems. That combo has been bulletproof for me. I hope this will be a better alternative.
George 03-19-2015 07:52 PM
I remember when that happened Erik. My non-sbus set-ups are a 6014 and Orbit Jack, so this "new" rx will definitely be welcomed, and a great solution!!
Hopefully more news will start coming out.
Tom Antlfinger 03-19-2015 07:55 PM
Rumors have a mid-2015 date in U.S. for about $220.00 list. Hopefully sooner. Hobbico still tight-lipped. Perfect match for 18MZ.
DiscoWings 03-19-2015 08:51 PM
Originally Posted by george (Post 12006314)
apparently this is in development and/or close to completion (hopefully)!! http://i615.photobucket.com/albums/t...psec7d2ea9.gif
omg plz!! Plz!!!!
George 03-19-2015 09:06 PM
Thanks for the info. Tom!
jescardin 03-20-2015 12:02 AM
A "little" detail: this receiver is compatible both with FASST and FASSTest systems.
Best Regards,
Jesus Cardin
Tom Antlfinger 03-20-2015 08:03 AM
A European jetster posted over on Brand X blog that Futaba will be introducing a new TX (T18SZ) priced between 18 and the 14......color screen, S-Bus, etc. probably at a Japanese Show in May.
Joe Westrich 03-20-2015 08:55 AM
Hopefully the Rx dual battery telemetry is more accurate on this unit. I am always getting falsely low batteries reading whenever running it through a battery back up system.... It is always 2 tenths low. Also Futaba....if you are listening.... can you take the voltage reading out to the hundredths. 6.6 doesn't tell me if it is 6.61 or 6.69 which is a huge difference in residual capacity for an A123 battery. Thanks!
stevekott 03-20-2015 09:02 AM
Wow! Very Nice!
modtron 03-20-2015 09:59 AM
This has been coming for some time, last I heard was that development was running over a year late now due to Futaba working on their new car system.
Modtron
Oxford UK
mr_matt 03-20-2015 03:04 PM
I was thinking of using of the Powerbox royal SRS with 2 SBUS receivers, now I am scared. Any resolution or lessons learned from your mishap?
Thanks and sorry you lost a plane. I had a 6014 and one of the smartfly boards and watched my planes fly away. Painful
mr_matt 03-20-2015 03:05 PM
Anyone heard if futaba has a new SBUS gyro coming? Even JR has an SBUS gyro already!!
Erik R 03-20-2015 04:16 PM
Matt,
My airplane had 2 7008's into a cockpit SRS, fed by 2 A123 batts. Everything was brand new, and built by a professional. Long story short, the airplane locked out on a knife edge pass, flew almost to the horizon, then snapped out in the direction the rudder was applied. Tx is an 18MZ, that has given me no other trouble. It did not go into failsafe, as I had the gear programmed to extend with failsafe, and they were retracted at impact. It wasn't a structural failure, as all the linkages were still intact, and the servos worked. Both batts had a full charge.
A few months later, I read where there were some compatibility issues with the early srs's and sbus Rx's, causing failures like mine. I've been told that a software update on older units fixes the issue, and newer ones don't have it. It seemed to be kept pretty quiet. I went back to using 6014's, and other power management systems, including the traditional cockpit, which have worked perfectly for me. Bottom line, the answer to your question is I don't know. Good luck to you.
Erik
mr_matt 03-20-2015 04:41 PM
THanks for the candor Erik. So much about these new gyros scare me. They act like you can turn them off if something goes wrong, but their software still stands between you and controlling those servos, even when they are "off".
Jetkopter 03-20-2015 07:54 PM
Matt, I use all the SRS power boxes with all the SBUS RXs in many different models never a problem. The one thing I don't use are the A123 packs. I flew the Cockpit SRS in my F4 with the first version software and Im still flying it now. We are never going to know what happened to Erik's plane , but it was a maiden so it could have been anyone of the new components. And don't be afraid of the gyros, you can turn them off!! I am installing a royal in a twin at this very moment and its royal # 4 for me and the previous 3 have been flawless.
Don
Erik R 03-21-2015 02:36 AM
Don
That's all 100 % true. I am not sure the Powerbox/sbus rx was the cause of the problem. I highly suspect it though.
wfield0455 03-21-2015 03:20 AM
While reading voltage to at least 2 decimal places makes sense, if they have telemetry in the unit I would hope they would track the current and capacity used for each receiver pack as well. Knowing how much capacity has been used from each pack would be far more useful then the battery voltage for an A123, no matter what the resolution.
Joe Westrich 03-21-2015 06:26 PM
Agreed, but have you known Futaba to jump ahead of the game in telemetry? I am hoping they swing at a lob pitch.If they jumped on the rest of what you said, I would beside myself.
