Igyro 3e delta wing setup
Wanting to use the 3e on my Eurosport and by all info I have gathered it states that the 3e
has automatic internal mixing for delta. The setup is already complete through my radio using the wing type elevon. So, what ports on the 3e should be used... elevator or aileron ? I'm only using one servo on each control surface. |
Hello countryboy,
you must Setup your Radio to "normal" mode - one aileron, one Elevator. Then setup the igyro3e to Delta wing mode with the powerbox terminal program. Then you have to connect one servo to the aileron port a and the other one to Elevator port a. Best regards, Karsten |
Originally Posted by Karsten022
(Post 12064881)
Hello countryboy,
what if I am using canard with the elvone ?
how can I setup the igyro 3e |
I am setting mine up as well, do you use the second elevator input for cannards?
How I have done it with the Spektrum 9350 in my Euro, is to just let the elevons do the mixing. I do not use the gyro on the canard. The Igyro would work the same way.
| All times are GMT -8. The time now is 09:58 PM. |
