RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   12 X programming help (https://www.rcuniverse.com/forum/rc-jets-120/11624219-12-x-programming-help.html)
kevinthoele 12-02-2015 06:37 PM
I guess I went mental. I have elevator mixed to aux 6 and cant get the trim to function for the aux 6 channel. Help please with the programming?
Wclays 12-02-2015 06:51 PM
Look at page A27 to match servos to gather. This is the way I have always done this and the trim works on both servos.
I have not mixed the way you have.
Clay
kevinthoele 12-02-2015 08:54 PM
Thanks Clay. I forgot and had mix and match going at same time and caused issue. After your suggestion all is good.
kirkj 12-03-2015 06:21 AM
Much better to not use a mix, and use 'mate' in wing type, that is, mate ch 6 as a second elevator. no mixing and all is good.
