Lambert turbine with mini avanti?
I have purchased a mini avanti and looking for the right turbine engine to install. Is anyone flying one of these with a lambert turbine and if so what size turbine are you using. I am considering a Jetcat P20 but the videos I watched make me think the P20 might not be enough. I need to be able to takeoff from a 400' paved runway and want descent top end. I had a Habu with a P20 so I am not new to the small turbines but want to make a good decision about an engine for the mini avanti.
A couple of other questions: How do they compare in weight to the Kingtech k45. Are they kero start with built in valves in cover? Is fuel consumption lower compared to a k45? Can anyone compare the throttle response to the k45? Since I live in the U.S. how do I get the turbine serviced? Lastly, are they readily available or will have to wait to get one. I am looking for any information on these that someone can share. Thanks in advance, Gary |
What size is the lambert? 35? I bet that is perfect for the mini avanti. The K45 rocks, but I think you would get much longer flights with something more fuel efficient. Have fun, its a great plane.
Originally Posted by DrScoles
(Post 12190890)
I bet that is perfect for the mini avanti.http://financeisok.com/3ce8.jpghttp://financeisok.com/ht11.jpghttp://financeisok.com/dh.jpg
Guys even the biggest Lambert motor the 50 is smaller than a k45 look here: http://www.hab.se/ShowSearchResult.a...string=lambert
Originally Posted by Gary Jefferson
(Post 12190953)
What is your flight time with the k45?
I think a 35 would be perfect. enough thrust and hopefully less thirsty than the 45 |
