RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   ECU Low Voltage (https://www.rcuniverse.com/forum/rc-jets-120/11632151-ecu-low-voltage.html)
sillyness 08-26-2016 06:14 PM
ECU Low Voltage
For a 3S LiFe, what do you set your ECU low voltage cutoff at?
Dave Wilshere 08-27-2016 03:48 AM
Its partly capacity/ C rating dependent. But The Li-Fe will generally collapse once each cell is below 3.2v so 9.6v.
With kero start turbines the biggest battery demand is start, when kero burner, starter motor and pump all kick in. If the battery supports this load generally it will run just the pump for the flight and then starter for cool down
Dave
