RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   flame outs (https://www.rcuniverse.com/forum/rc-jets-120/11633127-flame-outs.html)
smith john 10-06-2016 11:05 AM
flame outs
anyone having flame outs on jetmunt turbines john
jason 10-06-2016 11:24 AM
I had one a few years ago. After that I always remembered to fuel up before flying..
Jason
Andy Aldridge 10-06-2016 11:57 AM
Love it Jason. :cool:
Len Todd 10-06-2016 02:16 PM
We had one at our club that flamed out frequently. The problem was air in-leakage on the intake side of the fuel pump. If I recall correctly, it was at the UAT. Fixed the air leak and no more flameouts.
ticketec 10-06-2016 02:28 PM
No flameouts for me.
DrV 10-06-2016 05:30 PM
Had one 2 weeks ago on a M140xbl. Was on down wind leg with 1/3 throttle gears down getting ready to come around and land. Luckily my Jeti telemetry spoke " oh sh*t, flame out". No white smoke. Landed safely. GSU says "low RPM" UAT was full, main tank Full more then 1/3. No air bubbles anywhere. Since then I have taken the fuel system apart and all looks good. Have had 75 flights with this engine on an Ultra flash without any problems. 6MM PU SMC tubing all around and 4mm from from pump to engine.. Have no festos in the system. I flew 5 more flights that day without any problems. Still can't figure out what happened.
raron455 10-06-2016 06:33 PM
I have about 25 flights on my M160 MKII, no issues, runs flawless..
smith john 10-06-2016 08:34 PM
jason go back to bed
Gaspar 10-06-2016 10:20 PM
The most common cause we see at factory is related to failsafe, some customers programm the failsafe at same position as STOP position, so the mínimum radio glitch cause the turbine to shutdown.
My reccomendation is to start the engine, set half throttle and switch off the radio. The engine should reduce power during 2 seconds and then shutdown. If it stop immediately, then the failsafe is not correctly programmed.
Gaspar
stevekott 10-07-2016 12:45 PM
I had a flameout on a 200XBL on my Mig 29. I had use the Skymaster supplied felt clunk in the header and saddle tanks. I was lucky enough to make the runway. Put the whole system back up on the bench. Ran the file pump up to full power.
There is a surprisingly large amount of fuel going into a 200 size motor and you could see the walls of the UAT being sucked in, then after a few minutes the fuel in the UAT started to cavitate (boil) .
I removed the felt clunks and replaced.the UAT. Haven't had a single issue in 30+ flights. It's a great motor.
LA jetguy 10-07-2016 10:22 PM
I have a few M200Xbl and they are all plumbed with 8mm tubing. Just a barb reducer to 6mm before the pump. No problems what so ever. M140Xbl has 6mm all the way to,the pump.
David
smith john 10-22-2016 05:47 PM
tested engine the reason for flame out was the fail safe set up.thanks for all the help. john
