Ultra Flash - Ultra Fast with ATJ 140SV
Hey guys,
here is a video from flying this morning in Ein Yahav, Israel: https://www.youtube.com/watch?v=TIG6hTYTsgg I am testing the new ATJ 140SV on the Ultra Flash, flying together with my WDT - Wireless Data Terminal. Hope you guys like the video. NO GYROS ;) Lior. |
2 Attachment(s)
A couple of shots from this morning...
http://www.rcuniverse.com/forum/atta...mentid=2184949 http://www.rcuniverse.com/forum/atta...mentid=2184950 |
Lior,
that is insane! Can you get it clocked in Mph? Or Maybe Km/h? |
We estimate it at 500-550 Km/h
You wouldn’t happen to remember what gap you left between the turbine exhaust and the pipe? I’ve just bought the same turbine for my Flash to replace my P-100rx which failed.
Simon |
Originally Posted by Si_B
(Post 12376295)
Simon |
Cheers mate, will do the same.
Simon |
What servos and servo arms are you using Lior?
Originally Posted by i3dm
(Post 12266021)
Originally Posted by setxws6
(Post 12376342)
but in all my last years jets i have been using these bad boys - much more powerful, very smooth, super quiet and cost the same! BLS-3507 - Servos - RC Electronics |
Originally Posted by Dave Wilshere
(Post 12376446)
In dream land maybe...
Any of you ever heard of an UF having flutter issues on alierons in the 250-300 mph ranges?
(Post 12376527)
Originally Posted by txshan130
(Post 12376553)
I have not seen it with my eyes, but someone has showed me pics of an ultra flash that blew up. Guy said he had never seen anything flying that hard and it was full throttle. I don't doubt it though especially if the pilot was yanking and banking; These planes aren't meant to handle that. If I go full throttle it's normally for a speed pass or four point roll and I try to be as smooth as possible.
We have a UltraFlash here, powered by a ATJ 220 SV, clocked at 524 km/h.
He was flying with another Ultraflash powered by a Jetcat 140, and that was so Much slower. |
Lior,
I know you built this a while ago, but did you have to do any mods to get the ATJ140SV to fit? Just had a quick look at mine, and with the mounting strap hard up against the former I can only get 20mm max gap to the start of the pipe (not the bell mouth). Looks like I might have to remove a little of the former to allow the motor to come further forwards. Just wondered if you remember doing anything similar, or if you have a photo knocking about somewhere of the ATJ140 in your Flash? Cheers, Simon |
(Post 12378075)
Lior,
I know you built this a while ago, but did you have to do any mods to get the ATJ140SV to fit? Just had a quick look at mine, and with the mounting strap hard up against the former I can only get 20mm max gap to the start of the pipe (not the bell mouth). Looks like I might have to remove a little of the former to allow the motor to come further forwards. Just wondered if you remember doing anything similar, or if you have a photo knocking about somewhere of the ATJ140 in your Flash? Cheers, Simon i just pushed the engine as forward as it will go (against the former) and bolted in - it works fine. |
Got a Atj 190sv as far forward as possible full ducting no issues.
Leaves me around 20mm to the pipe (maybe a bit less). Seems a bit close?
(Post 12378083)
Originally Posted by hotspot 01
(Post 12378077)
Sure is not pushing it 444 kph level flight and the 190 is 22mm longer then the 140.
Just took some measurements. With the turbine mount up hard against the former I get 26mm. Might add bit of extra ply to widen the mount as the mounting screws are a bit too close to the edge of the wood for my liking. Shouldn't take long tomorrow to get the turbine in, will need a few wires moving about compared to the P100rx it is replacing.
Simon |
