RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   BVM Bobcat Manual (https://www.rcuniverse.com/forum/rc-jets-120/11636032-bvm-bobcat-manual.html)
N1cko 01-27-2017 01:13 AM
BVM Bobcat Manual
Hi,
Just wondering if anyone has a copy of a BVM Bobcat manual.
Kind Regards
Nick
LGM Graphix 01-27-2017 04:03 PM
What bobcat? Original/xl or composite?
N1cko 01-27-2017 04:29 PM
Original bobcat thanks
sirrom 01-27-2017 05:20 PM
email address
N1cko 01-28-2017 12:14 AM
Pm sent Sirrom,
Cheers
medjets 03-22-2019 04:22 PM
Bobcat manual
Originally Posted by sirrom (Post 12300406)
email address
I also need the manual. I bought a Bobcat XL from a friend. I sent PM. Thank you.
LLiddle 02-14-2021 09:06 PM
I know this thread is several years old, but I've just purchased a nice Balsa Bobcat and would love to have a copy of the manual for it. Does anyone still have a file that they can send me? [email protected] thanks.
https://cimg2.ibsrv.net/gimg/www.rcu...9b4648b1b.jpeg
Zeeb 02-14-2021 09:57 PM
ALL of BVM's manuals are copyrighted and available for sale from BVM. You might want to consider how much work went into the development of these models and buy a manual from BVM.....
LLiddle 02-15-2021 04:38 AM
Well, excuse me Mr Zeeb. I had no idea that they were copyrighted. As old as they are the copyrights have probably expired anyway lol
Should I send BVM a royalty on the sale of their used jet too?
Make sure you go around and shame the other dozens of posters who have asked for copies on these pages over the years, and then, get a life, AH.
And FYI, I have emailed BVM about the purchase of several other fairly expensive items and have yet to hear back from them.KMA
For the many other more positive and helpful members of RCU out there I'm still looking for a copy and will be glad to donate $50 to your local club for your assistance, because BVM seems to be too busy to help me. Thanks
Dawn Ellzey 02-15-2021 05:59 AM
You will love your Bobcat, I still fly both of mine. You might call BVM they are open 9-5 and close for lunch from noon to 1P.
Im sure Patty will be glad to help you. Sometimes email go to email no where or are simply missed.
Their number is 407-327-6333
LLiddle 02-15-2021 07:41 AM
Thank you for your helpful post. I'll give them a call and see if they will sell me a manual.
mongo 02-15-2021 07:46 PM
Lee,
my wallet thanks you for removing this temptation.
LLiddle 02-16-2021 12:31 AM
Hey Mongo. Gotta get one of Par's fans in the air. I've got mote work to do on the Hotspot so this looked like the perfect solution. Should have it here in about a week. I'll do a thread in Large EDFs on the Group.
c/f 02-16-2021 07:38 PM
Lee I have everything Bobcat XL plans for building, checklist manual for build ect give me a day to round up send me a mailing address, I need them back after you have a look around , sure dont want to be paying any royalties second time around.
LLiddle 02-16-2021 11:44 PM
Hey Mike, thanks. Yeah I decided to go ahead with the purchase. I was really just looking for cg and control throws and was directed by another helpful member to a place where BVM had them all listed. Also I found an old build thread that I skimmed through. So please don't go to all that trouble. I know I can count on you and others for advice if I have a specific question during setup or early flights.
One question. It looks like some ive seen pictures of have some down thrust in the turbine (motor pointing down in the back). Is that right? I know that with EDF power on the Fslcon 120 knock off that high speed exhaust under the stab would cause the jet to pitch up when power was applied.
c/f 02-17-2021 09:01 AM
Any of the pusher jets like these wether turbine fan prop will pitch nose as throttle increases so down thrust is proportional to how high off the wing centerline powerplant centerline is located. Then CG and powerplant HP factor in to degrees. Not really a function of stab heat.
Ill get a pic at lunch been to long but BVM will have the solution pre engineered in OEM assembly pieces if everything is OEM.
LLiddle 02-17-2021 10:29 AM
Thanks Mike. I think you're misunderstanding my question.
I had several Nitroplane Falcon/Bobcat in all three sizes.What I experienced was that when flown as a propjet the prop stream carried above and below the horizontal stab. In that configuration there was little to no pitch change with power change. But, when flown as an edf with all of the exhaust traveling below the stab, power added would cause the nose to pitch up severely. The concensus at the time was (and I think correct) was that the high speed airflow under the stab was causing downward "lift" at the stab, which of course raised the nose. If a long exhaust tube was added to carry the exhaust past the stab, the problem went away, or you could tilt the fan up in the front to create nose down pitch when power was applied.
It looks to me from pictures that the BVM Bobcat as a turbine has some nose up angle on the turbine installation.
If that's the case, a normal edf installation would need even more. So Im looking for that info to get ahead of any pitch changes that I may have to desl with. Thanks again for your interest and advice. Lee
edwarda10pilot 02-20-2022 02:21 PM
Help Identifying BVM Bobcat Version
Hello everyone. I know this is an old thread but I thought I would post here. I just picked up a BVM composite Bobcat from a friend. It does need a bit of work and all that I got was the airframe. I have the gears and most of the other stuff. However, I do not know which version I have. The plane I purchased is the one with the split elevators. Can someone chime in here and offer your thoughts as to which version this is?
Also, I have e-mailed BVM for a manual but can someone who has or has had one of these planes tell me what you used for the elevator servos?
Thanks in advance for your help.
Ed
edwarda10pilot 02-21-2022 08:02 AM
After sending some photos to Rob at BVM and reading thru some threads on this site and others, I think I have the built-up version and most likely the V2. I have owned some BVM jets in the past but this is my first Bobcat. I think it will be a great flyer with an 80 in it and will work fine off of some of the grass fields in our area.
https://cimg3.ibsrv.net/gimg/www.rcu...9d9c19cd04.jpg
chriskerby1 02-21-2022 12:55 PM
Manual
I have a manual send me your email and I’ll send it over
chriskerby1 02-21-2022 01:09 PM
These are what I have for elevator servos
MacGregor MG2810HV High Voltage Servo Mid Size 10kg/0.08s
edwarda10pilot 02-21-2022 01:29 PM
Hi Chris. PM sent. Thanks for the info on the elevator servos.
Ed
LGM Graphix 02-21-2022 01:30 PM
It's definitely not a composite bobcat. It's an early built up bobcat or bobcat xl.
chriskerby1 02-21-2022 01:32 PM
Yeah I’d say the standard bobcat
Dawn Ellzey 02-21-2022 01:42 PM
I measured the booms on mine BobCat and they are 36", the XL were a little longer and the fuselage was longer to hold a larger center fuel tank
Dawn
