Pegasus RPM Sensor
Is there an off the shelf part for that?
NJ0.8-4.5-N, Pepperl Fuchs
you are welcome... |
I said Pegasus but I just compared the diameter per the specs of the sensor you specified (4mm) to the one I pulled out (measured almost .253) inches, must be a different number or I have a usa model.
Thanks |
You are correct, I may have saved the wrong part number, still I believe it's the same supplier, they have many models, should be able to get the right one from them
