Fly Eagle Jets Hawk 2.66m Build
Well its time again for a new build thread. If you are like me I love to watch Jets move from start to finish. This thread is unique in that there is history behind this brand of Hawk. I purchase the FEJ Hawk 2.66m in the Yellow/Black Color. This first post will provide a list of items that I will be installing in the Hawk. As this build thread begins I ask that please keep this one clean and helpful for not just for me but for others that may end up purchasing this size or similar. As always My goal is to have other help me identify items that I could do better or different. So enough said here is a list of items that will be used in the Hawk:
Tank equipment: - Intairco Fuel Tank Vent Insert Kit X4 - Intairco High Flow Fuel Tank Bulkhead Insert X3 - Intairco iTrap Basic 50, Festo 6mm QS Connections - BVM Clunk X3 - Festo Tubing 6m Radio Equipment: - Jeti CB400 - Jeti GPS - Jeti MSpeed MX450 - Jeti Li Ion 5800 battery pack X2 - Cortex Pro - Blue Bird Full Aluminum Titanium Gears High Voltage Digital Brushless Servo #BLS-42A X 7 from http://www.rcmart.com - FEJ Light Kit - FEJ EVO5 muilti Valve with fail safe - FEJ Dual Valve X2 - Emcotec PWC4 Power Servo Connector Set for Four Servos X2 - HD 22gag servo Wire Items Needed: Turbine " Kingtech 180 or Jet Central Rhino?" Two Pilots |
As we wait patently until I get back to start the build. It looks like I will be going with a JC Rhino. Also I had made a jig to get exact measurements for the Xicoy CG Machine. This will be the first thing I do so that for those that get this model and size will have those numbers if wanted. Stay toned for the start.
Originally Posted by JoeJr1485
(Post 12317730)
Originally Posted by why_fly_high
(Post 12317963)
Do you recommend free weights or something like crossfit? ;)
LOL :rolleyes: |
Joe,
Nice to see that you are doing a build on the FEJ Hawk and doing it in the yellow and black, which I believe is a very cool scheme. Would it be possible to get some detailed photos of the insides (fuse, wings, etc) showing the construction on how its all put together. I would like to see this since I'm also thinking of a FEJ. Looking forward to following your build. Robert |
(Post 12317963)
Originally Posted by LimitDwn
(Post 12318062)
Joe,
Nice to see another build! :)
Originally Posted by megafly
(Post 12318143)
Hey Joe, Looking forward to your build thread! Just packing up the planes here on the island and getting ready to head home April 1st. MCBH gave us a FOUR day weekend just passed!!!
Duke and I are discussing a pilgrimage to Jet Power in 2018...stay tOned!!! Len |
Following..
Be great to see an FEJ Build from a Neutral perspective. |
Originally Posted by Len
(Post 12318606)
Originally Posted by tisdall_80
(Post 12318670)
Following..
This is great, I love build threads also.
I will say as I own several FEJ jests, Its worth the effort to cut a Square 1in from the root, about 1in wider than the rod that goes into the elevator. This is so you can verifier and strengthen the attachment point. Once you add some hysal to this critical part, then take balsa, and make tabs on all 4 sides, so the part you cut out will lay perfectly level, then Hysal it back in, if you use the super thin diamond cut off wheel from lows it will be a very small seem around the repair area. Post pics Im excited. |
Any Progress?
(Post 12322006)
Any Progress?
Any update?
Originally Posted by GULDUKAT
(Post 12322851)
Any update?
Thanks for the pictures.
Joe, I see some things that are typical to fej, some bad glue joints, they have cut too much from bulkheads that will cause them to crack. The biggest issue with this particular jet is seeing how the bracket is built into the stab. This was the major failure point before, plus seeing inside the wings and stabs checking glue joints. Not trying to be negative but you wanted this type of info, the honeycomb skin they used wasn't the problem it was them using it for bulkheads and ribs. People seeing new materials for the skin is the wrong way to look, they have changed that but all the other issues are still there. I try to bring that up with folks but they cant see past the honeycomb. These were things I didn't see until I had built other kits with correct layups. You're were I was six years ago, I have no doubt it can be built and flown successfully its just going to take some beef up and checking internals.
Thanks, for the pictures Joe, You had mentioned that there are a few things that you think need attention, would it be possible to get before and after pictures of the areas that need this extra work?
Thanks, Robert |
Joe,
Is this a brand new kit that you will be assembling or is this a used kit (factory disassembled from a unit they put together?) Chet |
1 Attachment(s)
This is how I know they haven't changed, not sure whats even going on here, is this for holding the pipe or just bad cutting. Plus the gear ply mount is split and will need to be fixed or the gear will tear out on the first hard bump.
Joe just be be careful, make the repairs and make sure you check the inside of the wings and the stabs. The aluminum cross beam on the stabs needs to extend almost halfway into the stab, the old ones didnt go in very far and would come apart in flight. I would be curious to see how the metal crossbeam is connected to the stab itself as well. http://www.rcuniverse.com/forum/atta...mentid=2208696 this looks like the bulkhead next to the stab mount, which should be beefy for strength but you can see they cut too much from it and some areas are very thin. Make some ply bracing to beef up the thin areas. |
Originally Posted by David Jackson
(Post 12323926)
