RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Turbine installation advice needed. (https://www.rcuniverse.com/forum/rc-jets-120/11640062-turbine-installation-advice-needed.html)
Justflying1 07-02-2017 02:20 AM
Hi,
l am installing two 6kg size turbines in an A10. I'm using 6 mm lines from breathers rite through the pump inlets. Both turbines will be independent. One tank one turbine etc. will I be OK to run 4 mm from pump outlet to turbine considering my pump will be close to the front of aircraft and engines obviously at the back or should I run it back up to 6 mm all the way to the turbine before reducing it to 4 mm.
i realise this question has probably been asked before but I am not sure on the best way to go about this.
I also was wondering what everyone has been using to remove glue from fuselage. This is just glue that is left behind from tape and it's not epoxy. In the past I have used a little methylated spirits diluted with water but wonder if anyone has any great ideas they would like to share.
SECRET AGENT 07-02-2017 02:58 AM
Goo gone, awesome stuff and won't mess up paint at all.
aquaskiman 07-02-2017 03:14 AM
Originally Posted by Justflying1 (Post 12349167)
Hi,
4mm will be fine for 60 turbines
Justflying1 07-02-2017 03:52 PM
Thank you Secret Agent and George
big fred 07-04-2017 05:13 PM
Just use fresh tape, stick it over itself again and again and the glue from the new tape will take off glue from the old tape. When you neck down 6mm to 4mm it is just like running 4mm the whole way, you will gain nothing to run 6mm.
Justflying1 07-04-2017 07:39 PM
Thank you big fred
gooseF22 07-09-2017 05:22 PM
Agree 4mm on pressure side fine.. try to run it all in one section with no or maybe one connector for cutoff
gooseF22 07-09-2017 05:23 PM
It's actually more important to get a good feed line into the pump with smooth run and no joints from air trap.
