Mini T1 Build
So she arrived today and I will share my discovery with you Cheers
3 Attachment(s)
I guess I will start with my setup
Radio JETI (new Jeti guy here help!!) CB200 with two REX and switch |
4 Attachment(s)
Servos MKS 747's all around
Also picked up the wiring harness from pacific rc jets....sweet |
2 Attachment(s)
Power
KingTechUSA K85 Dan at my field has this and it is super powerful. |
6 Attachment(s)
So here are some random pictures for you to see until and if I build her. If there are any details you want to see let me know...
8 Attachment(s)
More randoms:
2 Attachment(s)
front gear cover
Originally Posted by DepecheMode101
(Post 12373658)
(Post 12373653)
Originally Posted by Auburn02
(Post 12373676)
If you build? Why would you start a build thread if you may not build? Or was that a typo?
cheers |
Originally Posted by arizcowboy
(Post 12373678)
need any help on jeti setup let me know can get you programmed pretty quickly . Terry
I want to do the fuel gauge and alarms and bells and whistles I am already wondering how to program the nose door to open...... |
2 Attachment(s)
included hardware
4 Attachment(s)
Tanks
How do you clean the white dust out?? kero? |
(Post 12373681)
Thank you!!! I will be asking 1000000 questions.
When your ready will go thru and set up model etc
(Post 12373685)
Tanks
(Post 12373690)
When your ready will go thru and set up model etc 602-818-8598
(Post 12373691)
That would work or even just rinse with rubbing alcohol.
love this type of learning |
Just rinse them with water. Nothing magical about it ?
(Post 12373664)
front gear cover
can you share some pics of the door hinges mounting? |
8 Attachment(s)
Originally Posted by i3dm
(Post 12373781)
did the door come pre-installed?
can you share some pics of the door hinges mounting? Yes pre installed |
(Post 12373681)
I want to do the fuel gauge and alarms and bells and whistles I am already wondering how to program the nose door to open...... Are you using the Kingtech telemetry module for fuel gauge or installing a Jeti MFlow? |
The JP controller work fine for the door....at least the One I got with the T-1
Originally Posted by Dansy
(Post 12373849)
Originally Posted by ltc
(Post 12373843)
Use the built in sequencer to control door and gear timing. EspritModel just put up a new video last week for that capability.
| All times are GMT -8. The time now is 07:53 PM. |
