RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Tip Tanks toe-in ? (https://www.rcuniverse.com/forum/rc-jets-120/11645008-tip-tanks-toe.html)
vasek 02-24-2018 07:13 AM
Tip Tanks toe-in ?
Would a slight toe-in on jet tip tanks track better in the air ?
Dave Wilshere 02-24-2018 10:39 AM
Don't see it, its just going to add tip drag and possibly give you adverse (opposite) yaw
Rider-60 02-24-2018 11:39 PM
2 Attachment(s)
It is toe out on some full size aircrafts, the most noticeable being the F18F, but on a model I would just leave them at 0°.
However you can put them at a slight down angle, maybe 1° this will compensate the shift of the center of push.
ozief16 02-26-2018 08:58 AM
The super hornet is angled out for separation issues (ie dropping or punching stuff off so it doesn’t come back and bump into you). So not necessary for a model
The down angle of tanks on the FS is so they are aligned with the relative wind for normal flight (ie compensate for angle of attack). Makes sense in a model for lowest drag. For tip tanks I would think same incidence as the wing but there are smarter people here
hope it helps!
vasek 02-26-2018 03:04 PM
Thanks for the help guys.
So if I understand correctly, for a model, the wing tip tanks should be parallel to each other and same incidence as the horiz stab (which has 0* incidence in flight). Right ?
ozief16 02-26-2018 03:40 PM
I think the same incidence as the wing, but there are smarter people out there. Yes parallel
Dave
