RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Axle Lubrication (https://www.rcuniverse.com/forum/rc-jets-120/11649421-axle-lubrication.html)
Eaglepilot2 05-30-2018 09:24 AM
Axle Lubrication
What are some options for axle/wheel lubrication? I've been told about Super Lube, but is it a good high temperature solution? I had a wheel almost weld itself to the axle this weekend!
Thanks in advance.
grbaker 05-30-2018 10:09 AM
I use automotive high temp axle grease
scoeroo 05-30-2018 01:47 PM
Any liquid lube will just attract gunk and gum up the wheel bearing or bush sleeve
A dry lubricant such as graphite powder will work the best and also handle any heat issues
Locksmith supplies normally carry this product , good for all sorts of uses that need a dry lubricant
Len 05-30-2018 03:28 PM
I use Tri-Flow (PTFE - Teflon) which won’t attract dirt either. There are many brands on the market that satisfy this requirement, but it is a necessary thing or your axles will constantly be gummy and wear faster.
Eaglepilot2 05-31-2018 06:49 AM
Thanks for the suggestions. Much appreciated!
