Originally Posted by LA jetguy
(Post 12469945)
Yes... I use a single 3800 mah 3 cell LiFe... you split the output one straight to ECU... the other goes through a Jeti SBEC regulator adjusted at a steady 8.4... The regulator can be adjusted from 5-8.4v... Works great... Lighter jet flies better ;) David cheers |
I maiden the Wizard S yesterday.. Had 5 successful flights on it. It flies so stable and precise. Its not a speed demon as I expected but still VERY fast. It needed a few clicks of up elevator as I think its a bit nose heavy. Over time I will change the battery to a smaller battery to reduce the nose weight. The Ditex servos work so nice and well so quiet no buzzing at all. It was defenetily an attention grabber with the paint scheme. Not too many people paint their jets as the norm is paint in the mold.
Overall very happy with this jet and its definitely a keeper... Thanks again to Danny and the team at "Rocket Factory" for another outstanding project... David.. https://cimg0.ibsrv.net/gimg/www.rcu...b0edd9b698.jpg |
What’s the AUW of the wizard with all that equipment? The model should be overpowered with the 100 I guess. Paint scheme looks outstanding. Just built a similar size rebel hot, should have actually got the Wizard S quality wise. Chatty. |
nice
best part is hearing that ted is still around and doing stuff with modelers... MINAIR forever |
I saw one of thesep flying, pretty fast (and loud) with no bypass, unless the one I saw actually had a bypass, I did not look inside that one
Originally Posted by c_makhija
(Post 12471066)
What’s the AUW of the wizard with all that equipment? The model should be overpowered with the 100 I guess. Paint scheme looks outstanding. Just built a similar size rebel hot, should have actually got the Wizard S quality wise. Chatty. David’s is 14.24 lbs with empty tank and full UAT. A Merlin 70 and vinyl graphics would save a lot of weight. I cannot say enough about how nicely made this kit is. Everything fits well and this makes it a fun build. Not a beginner build but a fun one that a modeler will enjoy as it progresses. Danny |
Wow.. that's pretty hefty.. I was thinking of putting a K45 in mine and going as light as possible on the install.
M70 or K70. The K45 is the same weight. Danny |
https://cimg2.ibsrv.net/gimg/www.rcu...d5ea1dcf31.jpg
https://cimg3.ibsrv.net/gimg/www.rcu...9f688a545b.jpg https://cimg4.ibsrv.net/gimg/www.rcu...7017b465e4.jpg https://cimg6.ibsrv.net/gimg/www.rcu...74b58bc9df.jpg https://cimg1.ibsrv.net/gimg/www.rcu...b417c3e046.jpg https://cimg5.ibsrv.net/gimg/www.rcu...3d6aa32b4d.jpg This airplane does not get enough love. JP sent me some photos of one under construction and I have one coming to me. I another perfect fit for the X45. Actually, I saw David's at the field and new right away that I needed one. |
Nice and clean, in the white it kind of reminds me of a rebel.
Originally Posted by skunkwurk
(Post 12650521)
JP’s airplanes have the nicest glass work of any jet I’ve built. They are a joy to build.
I fly this one already for 3 years.
Powered by a Kingtech K70. Weight is 5,2 kilo (11,5 lbs) with full UAT. https://cimg8.ibsrv.net/gimg/www.rcu...c3f18d7cd.jpeg https://cimg9.ibsrv.net/gimg/www.rcu...192dc9bea.jpeg |
You added the little fins at the back. Was that to complete the look? Or to improve handling?
It is a nice model and your's came out pretty light. |
Originally Posted by jvaliensi
(Post 12650684)
It is a nice model and your's came out pretty light. I am always looking to save weight on my airplanes. Lighter is always better as it is very easy to make jets heavier but not lighter. For example I use carbon wing tubes and a 1 liter fuel tank and can still fly 6 minutes with mixed throttle settings |
Originally Posted by Didier
(Post 12650705)
I did the vertral fins to make the jet looks even better. But the bonus was it improved the handling of the jet even better. It feels like a “natural gyro”. Like most swept wing jets, it has a tendency to “Dutch roll”. With the ventral vins it improved this tendency a lot.
I am always looking to save weight on my airplanes. Lighter is always better as it is very easy to make jets heavier but not lighter. For example I use carbon wing tubes and a 1 liter fuel tank and can still fly 6 minutes with mixed throttle settings Do you buy direct or is their a dealer in the US? |
I've ordered directly from JP at ZN Line. He recommends the X45 and it is the turbine he uses in his. I'm getting mine built ready for servos and turbine.
That should be a super light, super fun jet. The one I built for David has an M100 in it :)
Originally Posted by F1 Rocket
(Post 12651018)
(Post 12650573)
(Post 12651061)
I really enjoy the wizard S.. wish it was faster😁 ... nothing my new X120 can’t solve 😉
I know JP a little and his intention was to design an aerobatic jet. Please make a video when you go full power with a 120. I wonder at what speed the airframe disintegrate. 🤣 |
(Post 12651015)
This was the scheme before I painted it to the Navy scheme https://cimg1.ibsrv.net/gimg/www.rcu...a81eedcde.jpeg |
I'm a fan of the Navy scheme, I think it looks much better!
And it would be easier to see in the air. |
Originally Posted by RCISFUN
(Post 12651663)
I like both schemes. But it is not my taste to paint a sport model in a scale scheme. I'd replace the Navy markings with the Wizard markings.
Where did you get the Wizard/ZN line sticker? Are there graphic files you would be willing to share? Cheers! |
| All times are GMT -8. The time now is 01:31 AM. |
