Wren Kero Igniter O-Rings
Hi Guys,
Does anyone know if the O-rings inside the Wren Kero Igniter are standard type or high temp Viton. The latter would make sense but I have a box of standard ones that fit perfectly. If I need to order the latter, does anyone know the prescribed size for this igniter?https://cimg2.ibsrv.net/gimg/www.rcu...4f07c6972d.jpg Thanks in advance. |
bump
Can anyone advise? I've tried Wren.....nothing yet.
Thanks in advance |
Dave
For sure they will be Viton. Paul at Turbine solutions may well have some..give him a ring. Otherwise carefully measure the ID and thickness and order them on line from polymax.co.uk . I expect they would be a metric size, though imperial sizes are also readily available. John |
Hi John,
Many thanks indeed for your help and suggestion to contact Turbine Solutions. Kind regards |
