AMT NL start up help
Hello,
I have an AMT Pegasus NL that I am trying to start. I don't have a data terminal and I have tried to get the computer (PC) interface to work but it is unreliable at this point. So I made a video of what I am seeing. I am running 2 channel mode, and I have "calibrated/learn RC" the ECU per the V2 ECU instructions and got successful "beeps" per the instructions. When I go to start the turbine, the 5 beeps start, but something bombs out (seems like at the 5th beep) and I cant tell which of the failure modes it is, or even if these are failure modes. A video i here, thanks in advance for any help. |
I think you need a 4s battery for that engine. My Olympus does that when voltage is too low.
Actually I mean it's a problem engine and you should send it to me for the price of shipping lol.
Thanks Jeremy. It is a 4 cell LiFE but I think I have a 4 cell lipo to try. Did you ever use the PC program?
I'll stick with it a bit longer, if I am about to throw it through a wall I will let you know first |
I have the PC program that allows me to change max rpm, plug voltage etc. I would double check with bennie but my Olympus hp needs a 4s lipo at 14.8v. I forget what the cutoff was but even my old (1997) NL olympus was a 12volt ecu, a 4s lipo is what I use. The 4s life probably isn't enough voltage.
looking on amt NL's site they only offer 4s lipo batteries so I would think all their hp ECU's are 4s lipo. Pretty significant voltage difference. They will calibrate below voltage but wont start below voltage. |
4s lipo amigo and be sure to separate the rpm sensor and egt cables from the starter motor / glow igniter cable. The starter motor and glow igniter initial amp draw is high and it’s possible the LiFe can’t keep up. 35c rated pack or higher is optimum. lastly Bennie is always best resource next to Jeremy Ofcourse ;-) |
Any luck?
Funny, right after you told me i tried a 4 cell lipo I had lying around and it went right through to start up. It was night time so I unplugged it and got ready to try it the next day.
Next day after 4 different batteries tried, it never spun again. I am setting about getting the PC interface to work as I don't want to troubleshoot this without being able to see what is going on in the ECU. Some setting must be wrong. Of course that PC program does not work either, when I move the throttle stick the pump voltage readout changes on the PC.... |
Originally Posted by yeahbaby
(Post 12487063)
Bennie is always best resource Good luck, JanR |
Originally Posted by mr_matt
(Post 12487414)
Originally Posted by LGM Graphix
(Post 12487465)
check that the glow plug didnt burn out. If it's burnt it won't initiate a start sequence
I took another video. Thanks for the help I do appreciate it. |
Matt, when you did your start sequence I heard the typical beeps before it should initiate a start followed by a single lower pitched beep that lower pitched beep indicates a low rpm error. I had a pegasus that did that to me and it was the rpm sensor had failed. To be fair the sensor itself hadn't failed but the cable connecting it was pinched and caused a problem. I took the pressure off the cable and it solved the issue in my situation. I wonder when you are connected to the PC if you blew air into the engine to spin it if you would get an rpm reading. Funny it worked once for you but not now. Check the connection on your rpm sensor at least. In all seriousness though if it's not something you decide you want to mess around with let me know. I would be interested in the engine.
For what it's worth, unless you want a more current engine I do believe this engine is more than worth having Bennie look at. |
Probably a useless idea but did you try reversing the throttle channel
Originally Posted by fw190pilot
(Post 12488086)
Hi,
This is Ray from AMT. Please donload the latest version of TMC from the web site (Download TMC 2.1.5.1) What firmware is in the ECU (see sticker). We can do some tests if you have a CTF switch. 30% is heater/glowplug. 50% is main fuel valve 80% is starter Place the throttle to this setting en push the CTF switch. Cheers Ray |
Originally Posted by RayStruik
(Post 12488150)
Hi,
This is Ray from AMT. Please donload the latest version of TMC from the web site (Download TMC 2.1.5.1) What firmware is in the ECU (see sticker). We can do some tests if you have a CTF switch. 30% is heater/glowplug. 50% is main fuel valve 80% is starter Place the throttle to this setting en push the CTF switch. Cheers Ray My ECU is marked version v.26B. And it is propane start. So I used PC SW version : V 1.8.0.9 For version 2 ECU propane start, up to VX29 ECU software Are you saying to use PC SW version: V 2.1.5.1 For version 2 ECU/EPV kerosene start, for VX36 ECU software Thanks EDIT; I ran version 2.1..5.1, all the results are the same as my last video, other than the "Supply Voltage" now seems to read the correct ECU voltage. Everything else is the same as the video, no starts, no ability to download the ECU. |
Ok.
The TMC version is for both propane and kero the same. Only the ARS file is different. You are running on 2400 baud I assume. Check if control (options page) is set to none. If you disconnect the glow plug is the light going off in the TMC? Is the glow plug glowing now? If not check if the glow plug is still ok. If so than take out the glow plug, connect it to the ECU (red wire) and hold it against the casing of the turbine (black wire). Go into starting phase by putting the switch into running position. Cheers, Ray |
(Post 12488267)
Ok.
The TMC version is for both propane and kero the same. Only the ARS file is different. You are running on 2400 baud I assume. Check if control (options page) is set to none. If you disconnect the glow plug is the light going off in the TMC? Is the glow plug glowing now? If not check if the glow plug is still ok. If so than take out the glow plug, connect it to the ECU (red wire) and hold it against the casing of the turbine (black wire). Go into starting phase by putting the switch into running position. Cheers, Ray Where is the light in the TMC for the glow plug? I have checked the plug before but I will do it again. I never saw a failed glow plug indicator in the TMC interface. Thanks again, |
Amt
Hey Matt,
I know your dad here in Hendersonville, and I have a AMT Pegas air start ECU that is my spare, which I am not using along with a data terminal that I could send, to get you going with the least problems. I have a spare rpm sensor also. You can email me direct; [email protected] or PM me and I will give you my cell #. Johnny Woods |
| All times are GMT -8. The time now is 10:28 PM. |
