Unilight 8Ch Pro Controller Setup
Anyone familiar with this controller? I have the Windows configuration program running on my laptop and its communicating with the controller in Live mode. Every time I edit the program and attempt to save it to the controller or upload it to the controller for testing, the program reports the configuration not saved and Live mode reverts to previous program settings. Same thing happens when saving edited configuration to a local file on laptop. Help link within configuration program appears broken and I'm stumped!
Any help gratefully received. Malcolm |
Can you save the program you want before sending it to the unit?
That may help with having to make a new light program every time. I have also also found that doing one change at a time and waiting for it to load on the controller works for me. And the unilight folks reply to emails really well too! Good luck! |
Originally Posted by Malcolm H
(Post 12504090)
Any help gratefully received. Malcolm Tim |
Rav,
Saving makes no difference, it still says "program not saved" when pressing play. Tim, I'm pretty anal about following instructions but will try again. Malcolm |
Sometimes you have to try a different usb port too. I believe you can actually look at the port and see if it is connected.
(Post 12504248)
Rav,
Saving makes no difference, it still says "program not saved" when pressing play. Tim, I'm pretty anal about following instructions but will try again. Malcolm Tim |
Thanks guys, im away from home just now but will try again when I get back. Malcolm |
I remember having an issue until I selected the right comm port on the top left section of the programming window. |
| All times are GMT -8. The time now is 06:57 AM. |
