RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Comp arf / skygate Hawk 1: 3.75 (https://www.rcuniverse.com/forum/rc-jets-120/11665544-comp-arf-skygate-hawk-1-3-75-a.html)
arizcowboy 06-03-2019 11:40 AM
Have a question hoping someone out there can answer ? On the big Hawk , the thrust tube sticks out the rear by about 2 inches . I have always been on the understanding that we keep the rear of the pipe about 3 mm to 6mm inside of the body. to help with air scavaging and cooling of the pipe . All the pictures of Hawks flying show the pipe outside the fuselage by that distance . thanks Terry
Dave Wilshere 06-03-2019 12:45 PM
Mmm no.
The SG CARF pipe sticks out the back around 12mm. 2” is 50mm and you have never seen this.
The inner pipe should be around 10mm short of the outer cool wall pipe
arizcowboy 06-03-2019 01:25 PM
Originally Posted by Dave Wilshere (Post 12529004)
Mmm no.
I agree with what your saying. but look on comp site and a couple of videos . that's more than 12mm . from the stock carbon bi pass to back of hawk is 940 mm around 37 inches the stock pipe is 39 inches . has to be a reason csnt be turbine choice because the by pass fits the frame rails
Blancr 06-03-2019 01:31 PM
For what it's worth mine sticks out about 12mm as Dave says.
Bob
arizcowboy 06-03-2019 01:44 PM
Bob
thanks . do you have a picture by chance . to get that I agree that's correct measurement I have to cut down front of by pass .
arizcowboy 06-03-2019 02:02 PM
https://cimg1.ibsrv.net/gimg/www.rcu...4c95f88c2b.jpg
from comp / arf site
arizcowboy 06-03-2019 02:09 PM
Originally Posted by arizcowboy (Post 12529020)
with pipe up on the by pass I have 25mm out the back . about 1 inch
arizcowboy 06-03-2019 05:50 PM
thanks for your input talked to Andreas . 12mm is good . it's basically to be more scale. so I will move turbine ahead and it will work great . Terry .... badboyzrc.com
