How to start twin turbines, individually.
Currently I start my A10 with Jet Central Cheetahs with a single trim/throttle stick combination and they both start together. At times they fail to start together. It maybe a better idea to start them individually. What is the best method for this?
thanks in advance. |
Just unplug one cable wait until the one turbine starts plug it back and do the stick up and back and the second turbine will do the start sequence separately, I do the all the time with my twin turbine setup specially with propane starts
I recall a post on here describing a mix through a 3 position switch which would hold one engine at idle throttle, allowing the other to see the throttle full/ idle command to initiate start. Once that engine had started, you could toggle to the opposite side of the 3 position switch to hold that engine at idle allowing you to start the second engine. 3 position switch in the middle would give throttle control to both engines. Before start, just sending an idle throttle command to the engine will not initiate a start, and once started, holding idle will not affect the running engine. Also a good way to simulate a flame-out in flight.
Position 1 - L Engine Idle/ R Engine Active Position 2 - Both engines active Position 3 - L Engine Active/ R Engine Idle A single throttle kill switch would shut down both engines irrespective of the 3-position switch setting. I'm considering the same for my current build project, but I haven't implemented it yet. Paul |
You can use 2 switches to enable the 2 engines and one as kill switch to both. Don't use trims for engine control, it's lame and error prone.
Originally Posted by mauryr
(Post 12623679)
Trims take a long time to actuate and if you miss one or 2 clicks by mistake, you may set your engine to a different idle point. The engine may start anyways, but shutdown in flight due to a bogus idle signal.
Switches positively set a very specific idle signal which never changes. Moreover, if you accidentally flip a switch (never happened to me in 10 years honestly, just choose a switch that's far from reach when actuating your flight controls) - the engine will not shut down immediately: you can use throttle cut functions which have some hysteresis and will not just send the 'off' signal, unless your throttle is also at near idle. Finally, you can also set a sound to play when flipping the switch, to ensure you're aware of what you're doing, something like "Engine shut down" etc. Obviously this is just my opinion on the matter, but I'd never recommend using trim over a switch, it's just that much more immediate. |
I got two on/off switches connected to red wires of turbine throttle ch.
One on, start -> after engine runs switch another on and throttle up and down. Another starts easily.. Later I was lazy and started both at the same time... |
It all depends on the System JR, Futaba, Jeti ect....... some have locking switch (that’s what I used) some you can change the trim value so one or 2 click brings you to full trim..... so it really depends on what TX you have......
Originally Posted by Auburn02
(Post 12623707)
Can you expand on this theory? It's much harder to accidentally hit down trim 3 or 4 times than it is to hit a switch while flying. Not that I have a habit of accidentally flipping any switches, but using trim rules out nearly any chance of it entirely.
Makes sense. I fly with a Futaba 18SZ so no locking switches, I like the trim option myself - but I do adjust trim increment so that it's just 2 or 3 clicks from min to max value.
I have a Skymaster small A10 and used a Futaba 18mz. IF you’re using Futaba I can send you the file, that allows you to use a 3 position switch to start one at a time.
only limitation I recall was you couldn’t shut down one engine at a time. if you’re going down this route I’d ensure there was some foolproof way to ensure you move the switch back to give you command over both engines before you takeoff. it’s funny how an A10 can fly around on one engine and just feel a bit “funny” |
I put throttle trim on a knob and that works for me!
Originally Posted by bidrseed2
(Post 12623782)
Originally Posted by Ragz
(Post 12623633)
thanks in advance. Would be relative easy to design and make by some electronic company's in rc modelling? I would be interested! :) Rgds, Gerald |
You can do that with a simple programmable mix assigned to a switch.
Originally Posted by Gerald Rutten
(Post 12624057)
I remember in the ductedfan era there was a British company making a small device where you could connect a single RX throttle channel and second channel input (ie Flaps) and two throttle output channels. This way you could lock one engine to idle while working on the other, for example flaps 120% down or another free channel.
Would be relative easy to design and make by some electronic company's in rc modelling? I would be interested! :) Rgds, Gerald https://cimg3.ibsrv.net/gimg/www.rcu...0cfc78354e.jpg If you happen to have JetCats, they can be programmed to start individually by setting one to "Immediate" start and one to "Sequence". The manual explains how. It's also good to be able to disconnect battery power individually to the turbines. That allows you to reset them, one at a time if you get a bad start. |
(Post 12624057)
Originally Posted by Dansy
(Post 12624063)
Easily done with modern TX programming.....
Cheers, Gerald |
Originally Posted by CraigG
(Post 12624061)
You may be referring to a product called the Mini Hobby Twin sold by Atlanta Mini Hobby, which works pretty much as you described:Mini Hobby ATL, Inc.
(Post 12624115)
Sorry, I might be a bit old school :rolleyes:, I might need a new transmitter for that..., maybe the time for that is there when I start building the twin.
Cheers, Gerald |
2 Attachment(s)
Attached is how I did it on a Jeti DS-24 soem time ago. It worked very well. It was somewhat complex due to a complication on how Jeti produces the servo values when using mixes.
I have since done it in the Powerbox CORE with similar techniques and it was much more straightforward. Hope that helps. |
Hello Edgar, thanks for the jeti instructions. Do you have the Core instructions written down as well? I use a Core as well.
thanks Anurag |
(Post 12624294)
thanks Anurag I will take some screen images tonight that should take you there. Basic concepts are the same; - one switch/button to select individual turbine control or not - one 3 POS switch to select which turbine(s) to control when in independent control mode - Two mixes per turbine to send the right values to it based on stick position and mode of control (send either an idle signal or send the throttle stick position) - use of throttle cut or equivalent to manage the trim. You don't want to share the single trim button in the radio for two turbines. |
Thank you Edgar... look forward to it.
I just recreated something similar to Edgar's method on my DS-24, using 2 physical switches, 6 free mixes and only 2 Logical switches.
Physical Switches 3 position for selecting 'Left Idle - Right Active'/ 'Both Active'/ 'Left Active - Right Idle' You need to create the following functions first;2 position for Throttle Cut Throttle (default assigned function) Do not assign the System Throttle Cut - it will not work.Throttle - L (do not assign a control to it) Throttle - R (do not assign a control to it) Throttle Cut (assign to your normal Throttle Cut switch) Create Logical Switches L1 - Left Active/ Right Idle - 3 position switch AND Throttle Cut False(Set 3 position switch true for Middle and one end position) Create MixesL2 - Left Idle/ Right Active - 3 position switch AND Throttle Cut False (Set 3 position switch true for Middle and other end position) Mix 1 - Throttle to Throttle - L based on L1 Logical Switch True - Simple Linear Curve (-100 to +100) Mix 2 - Throttle to Throttle - L based on L1 Logical Switch False - Constant at -100% (to hold at idle) Mix 3 - Throttle Cut to Throttle - L - Based on Throttle Cut Switch position - Constant at -125% Mix 4 - Throttle to Throttle - R based on L2 Logical Switch True - Simple Linear Curve (-100 to +100) Mix 5 - Throttle to Throttle - R based on L2 Logical Switch False - Constant at -100% (to hold at idle) Mix 6 - Throttle Cut to Throttle - R - Based on Throttle Cut Switch position - Constant at -125% Paul |
Anurag,
I posted a CORE plane program with the setup/mixes etc for the individual control of the turbines in here. You can use "save link as" to download. The file extension should be .xml You may notice that the mixes that are active when the turbine is connected to the throttle stick don't start at -100. This is because I use the servo cutoff in a separate switch for trim-up/trim-down. In my case I have a safety switch for that. Hope that helps |
Hello Edgar,
thank you. Sending you a PM. |
Futaba setup for twin turbine startup
Hi, I message you the other day, wondering if you still have that file, as I have a 18mz, would greatly apricate it.
Im not new to RcUniverse, changed email address and cant remember old pass lol. Thanks Paul
(Post 12623782)
hai all,
if anyone has that file for futaba 18mz for the twin turbine startup, if you do, could please is pass it by. Bidrseed, no longer has it. thanks |
In case anybody is interested that is using JetCat engines with the ECU V12’s and Jeti, this is what I’ve setup. With this I have individual control of both engines, running or shut down. I do not like to use switches for this, just to easy to bump one, I use dials.
Left and right dial (L and R engine): - Full left is cut off (power off/shut down, trust lever disconnected), - Center is engine start and trust lock at idle, - Full right is start and trust lever connected. This way I have full independent control. I can run up an engine while the other one stays at idle. The ECUs need to be programmed so that the engine will start with high trim only, no trust lever to full needed to initiate the start. Also I use a range of -50% +50%. “Shutdown” at -70%. Fail safe will be outside that range. Engine 1 and engine 2 ‘servo setup’ needs to be as follows: [img]blob:https://www.rcuniverse.com/d743331f-ab38-4c94-9042-bda48d0c1692[/img] The trust lever has a total of 4 mixes to engine 1 and engine 2. ENGINE 1: Mix 1, normal operational control : Trust lever to engine 1. This mix is active with a dial full right. Inactive with dial 1 full left and neutral. [img]blob:https://www.rcuniverse.com/31e559cc-a4f2-4ea0-a042-705919047ae6[/img] [img]blob:https://www.rcuniverse.com/eaeb4fbf-9fcc-4595-b529-dc6b04a1f043[/img] Trim 2, shut down: this mix is active with dial 1 full left, inactive with dial neutral and full right. [img]blob:https://www.rcuniverse.com/c3baa9d6-261f-400c-9fc0-0a9eebc9bdf8[/img] [img]blob:https://www.rcuniverse.com/82700379-3c93-4bd4-907d-aea2fe61bae5[/img] With the dial at neutral, there is no mix active so the ‘output’ will default to -50%. That will start the engine and keep it at idle Setup for engine 2 is obviously the same, just a different dial. |
