Two Turbines into one exhaust
Question, has anyone run two turbines into one exhaust?
Basically a bifurcated pipe in reverse, obviously with a larger outlet diameter, This is for a large potential project where as you have the additional safety of a twin setup yet in a model with a single exhaust. Regards, |
Yes , I’m not sure what model it was but lots of guys know this jet from Kentucky jets 2018 and 2019 , same person has the twin joined rebels pro together to one very interested jet
I don't think I've seen that done before, but you might want to checkout how the big 1:3 scale F-104 from Airworld setup was done and maybe go that route if your model is big enough.
I think RCPete did a Havoc
Am |
RC Pete had the twin into one pipe and I have seen somewhere guys in Europe do the same with some huge models.
Thanks for the replies, yes I have seen the two exhaust setup on the big 104's.
Just wondering if you could port both exhausts into the same exit, not two separate ones. Regards, |
This is Pete's Havoc with two into one. I'm sure he has some pics of the install somewhere.
https://cimg5.ibsrv.net/gimg/www.rcu...3cf05ce5b5.jpg https://cimg4.ibsrv.net/gimg/www.rcu...dd42fea882.jpg |
Unless you can guarantee both turbines throttle exactly the same time I think you will have issues with the lead turbine ‘sucking’ on the slower one and that’s if the turbulence didn’t make a horrible sound.
I think you would get more thrust out of the split exit set up too. |
Yep that is exactly what I was worried about, basically a pressure differential and not sure where it could affect flows.
Regards, |
Some years back before we had the bigger motors there was a big F86 in Europe set up with two motors feeding into one big pipe.
I know there are pictures on the internet somewhere but i couldn't find them of this 1/4 scale F16 with 4 G Booster 160 turbines down a single tailpipe.
Nice find Jeremy!
Think you will find the pipe was divided into 4
Originally Posted by Dave Wilshere
(Post 12641125)
Here are some pictures of rcpetes havoc with a reverse bifurcated pipe.
https://www.rccanada.ca/rccforum/sho...9&postcount=36 |
I’ll see if I can find the article in an old JetPower on the F-16, I still thought the big pipe was divided.
Pete’s Havoc with the long inlet joining tubes I can see how that worked. So I guess it goes back to the OP and whether he has the big fat fuselage space to do the same. |
Yep pretty cavernous space in the fuse so that is not the issue.
As said this a potential project, I have two on the cards as a next build project both with their quirks not sure which way I will go yet. Thanks for the input. Regards, |
