Skymaster A-10/A10 Build Series.
The new big project for the channel has begun!
Thanks for checking it out! |
Let the Build Begin!
Thanks for watching! |
Wing complete
tail complete
Great building!!
Many of us like pics too!! |
https://cimg1.ibsrv.net/gimg/www.rcu...4ebb4b2fbc.jpg
Wing as it comes out of the box. https://cimg8.ibsrv.net/gimg/www.rcu...ab0293a3ab.jpg Overall shot of the wing before Pylons mounted. https://cimg9.ibsrv.net/gimg/www.rcu...a21acc6e81.jpg Complete Wing gear extended. https://cimg0.ibsrv.net/gimg/www.rcu...4d3bb518fe.jpg Complete wing gear retracted. https://cimg3.ibsrv.net/gimg/www.rcu...f28cf29953.jpg Wing going into storage into the SAFE REVOC Bags! |
https://cimg0.ibsrv.net/gimg/www.rcu...69b9ac9ee0.jpg
Arm Geometry for Air Brake. Initially setup with a JR Nylon Super Horn but was way too flexy. Switched to 15mm sea craft aluminum arm. https://cimg6.ibsrv.net/gimg/www.rcu...dacc4abfa4.jpg Overall Shot. https://cimg0.ibsrv.net/gimg/www.rcu...cd0071cb3a.jpg |
https://cimg1.ibsrv.net/gimg/www.rcu...3732888d41.jpg
Rudders are fairly simple to put together. Everything is just tite! https://cimg2.ibsrv.net/gimg/www.rcu...5fd51cd811.jpg |
https://cimg1.ibsrv.net/gimg/www.rcu...67d351cc30.jpg
Best way I could come up with to mount the Elevator servos was to use the metal L brackets supplied. https://cimg2.ibsrv.net/gimg/www.rcu...295d1a4b6a.jpg This required some access holes. This entire area is hidden by the fuselage when assembled so conceivably the access hatch could be 1" wider to make this easier. Although the manual talks about using an internal setup which we are not using. https://cimg3.ibsrv.net/gimg/www.rcu...ebd872fb84.jpg Holes added for access. https://cimg4.ibsrv.net/gimg/www.rcu...e760fe5d3e.jpg Servo arms and slots installed. https://cimg5.ibsrv.net/gimg/www.rcu...5cd90f81e8.jpg Elevator setup complete. |
https://cimg4.ibsrv.net/gimg/www.rcu...d0f9e791e5.jpg
Scale fans do not come installed. Glued in place with West Systems Six10 https://cimg6.ibsrv.net/gimg/www.rcu...ea847145af.jpg Fill Sand, Fill sand, Fill sand. https://cimg7.ibsrv.net/gimg/www.rcu...ea447765bc.jpg Complete and primed. Used etching primer. https://cimg9.ibsrv.net/gimg/www.rcu...ca35d35561.jpg Complete painted. Thanks Home depot for the color matches! Great job! https://cimg0.ibsrv.net/gimg/www.rcu...61f697f66d.jpg Installed and looking great! |
Thhttps://cimg3.ibsrv.net/gimg/www.rcu...fdc0f2b05a.jpg
Pip mounted to bell mouth with Rivets. https://cimg4.ibsrv.net/gimg/www.rcu...6ab46076c3.jpg Short rivets used so wood mount fits over. https://cimg5.ibsrv.net/gimg/www.rcu...99ad0b88af.jpg Pipe assembly mounted to wood mount. https://cimg6.ibsrv.net/gimg/www.rcu...efcf93ff52.jpg SWIWINI 140's mocked up https://cimg7.ibsrv.net/gimg/www.rcu...9d0a050084.jpg https://cimg8.ibsrv.net/gimg/www.rcu...e2b27c4451.jpg Engine mounted. https://cimg0.ibsrv.net/gimg/www.rcu...382d80a01f.jpg Front view https://cimg1.ibsrv.net/gimg/www.rcu...dc89817158.jpg Back View https://cimg2.ibsrv.net/gimg/www.rcu...142ea93485.jpg Overall view. This will all get removed now to paint the inside of the pod. |
What weight are the SW140’s? Did you weigh those turbine rails before installing?
I spent ages removing weight from the pods! |
Originally Posted by Dave Wilshere
(Post 12693459)
I spent ages removing weight from the pods! The Swiwin 140's come in at 1395 Grams for just the engine. All 4 engine rails together come in at 206 grams (51.5g each) What engines have you run in the A10? |
Jon
Missed the question! JetCat P-130’s. Your rails are lighter than the original ones supplied in my kit, but I made composite rails where all four were around 120g Dave |
mid section main start up plate and tank installation.
No many photos of this section
https://cimg1.ibsrv.net/gimg/www.rcu...7c05587050.jpg engine and pipe in place. https://cimg2.ibsrv.net/gimg/www.rcu...4c234a2e32.jpg Main startup plate in progress. https://cimg5.ibsrv.net/gimg/www.rcu...a00ef1eb9b.jpg https://cimg6.ibsrv.net/gimg/www.rcu...81c90cff0c.jpg Final Startup plate in place. Not made to full width so you can see the fuel tanks filling up. https://cimg7.ibsrv.net/gimg/www.rcu...b1bc95329c.jpg The mess of wires and tubes. https://cimg8.ibsrv.net/gimg/www.rcu...a4556ef9ef.jpg Wing connections. Grey/white is the gear lock/unlock pair. The other 3 are gear up/down and brake. |
https://cimg4.ibsrv.net/gimg/www.rcu...e9d6df362a.jpg
Plumbing complete and fuselage ready to join. https://cimg5.ibsrv.net/gimg/www.rcu...fdd70b692d.jpg Airframe joined. https://cimg6.ibsrv.net/gimg/www.rcu...aa12e32dcb.jpg Setup cradle system from Random RC/Random Heli and it works great! First time using it and it was a wonderful work stand. https://cimg7.ibsrv.net/gimg/www.rcu...c12a7b8f05.jpg Another view https://cimg8.ibsrv.net/gimg/www.rcu...4e234b54e3.jpg Infinitly adjustable. |
https://cimg0.ibsrv.net/gimg/www.rcu...8f3b00d4a7.jpg
Location of soft pin switch. https://cimg1.ibsrv.net/gimg/www.rcu...f37f2610e4.jpg Cables run to front https://cimg5.ibsrv.net/gimg/www.rcu...38fb78268e.jpg Main radio tray. https://cimg2.ibsrv.net/gimg/www.rcu...24638f1a12.jpg main radio tray complete https://cimg3.ibsrv.net/gimg/www.rcu...b7c7a8ab50.jpg front battery tray system. https://cimg4.ibsrv.net/gimg/www.rcu...a58b7a4c2a.jpg |
https://cimg1.ibsrv.net/gimg/www.rcu...4d9cf204de.jpg
https://cimg2.ibsrv.net/gimg/www.rcu...bddb76cadc.jpg https://cimg3.ibsrv.net/gimg/www.rcu...19fe067d57.jpg https://cimg4.ibsrv.net/gimg/www.rcu...c90aca5df0.jpg https://cimg5.ibsrv.net/gimg/www.rcu...ef9f68ae2f.jpg https://cimg7.ibsrv.net/gimg/www.rcu...8e8dbeab30.jpg |
