RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Best Pneumatic Quick Connects ? (https://www.rcuniverse.com/forum/rc-jets-120/11694123-best-pneumatic-quick-connects.html)
IFLYBVM2 10-14-2021 04:45 AM
Does anybody know who makes these pneumatic quick connects ?
Trying to sort the most reliable ones and these seem pretty nice.
I have had the tangs on the Robart ones fail under pressure before, so a bit hessitant on using them.
https://cimg3.ibsrv.net/gimg/www.rcu...5d7037e170.jpg
Dansy 10-14-2021 05:02 AM
I like the Festo best….compare to anything with o’ring…
Auburn02 10-14-2021 05:44 AM
Same for me, if I'm putting any kind of quick connects in a semi-permanent location to make for easier gear or valve removal, I like Festo push connectors. At wing joints that are frequently disconnected if I can't make BVM EZ-air connectors work, I have never had a problem myself with the Robart twist lock connectors. I don't like the aggravation of the pictured style that requires multiple turns while I'm precariously balancing a wing and trying to hook things up at the same time.
Len Todd 10-14-2021 05:57 AM
I use BVM's connectors. They are kind of a pain to fasten and unfasten. But, I have had a Robart connector fail to engage properly. When I retracted the gear, all the air escaped and then the giant p-40 cart-wheeled on the resulting belly landing. Basically I hate air operated gear But I have been stuck with it on the two BVM planes.
IFLYBVM2 10-14-2021 07:09 AM
Did not know BVM made those-
picture ?
Will they work with 1/8 airline ?
Len Todd 10-14-2021 07:46 AM
BVM mostly uses very small air lines. The smaller the line, the less air used for an actuation = more actuations and less weight.
If you want the info, you might want to consider taking the time yourself to look them up online!
JSF-TC 10-14-2021 08:46 AM
They look similar to the Airpower airline disconnects, which I really like. I have used them for years and never had a problem.
https://cimg4.ibsrv.net/gimg/www.rcu...7bf3703b53.jpg
Boomerang1 10-14-2021 05:01 PM
I use Luer Lock connectors, a medical air line connector which has been available for model use from various hobby suppliers over the years.
https://www.drifton.eu/shop/108-fitt...nd-connectors/
Easy to grip with fat sausage fingers, no O rings to perish, light, available in different colours, never had any problems.
Last lot I bought from KMRC Jets.
https://cimg3.ibsrv.net/gimg/www.rcu...43c0cd0afc.jpg
CARS II 10-14-2021 05:42 PM
https://cimg9.ibsrv.net/gimg/www.rcu...716a1b1193.jpg
CARS II 10-14-2021 05:45 PM
I've been using the Robart ones for decades and have use the ones shown by the OP.
Both have worked for me as they should for years, no failures.
Auburn02 10-14-2021 08:16 PM
These are what BVM included with an E-brake I got from them, I just didn’t know what they were called or who made them so I could not recommend. They work quite well also.
RCFlyerDan 10-15-2021 09:28 AM
+1
Boomerang1 10-15-2021 03:12 PM
Until ......
Was happy with these for years until an O ring split, fortunately during a pre flight, leaving me stuck for the day.
Lesson learnt, pack a couple fresh spares if continuing to use them.
CARS II 10-15-2021 04:15 PM
Ah!
Same here 😁
CARS II 10-15-2021 04:16 PM
https://cimg4.ibsrv.net/gimg/www.rcu...2b2af891d6.jpg
found it hose here.
sysiek 10-15-2021 05:01 PM
Bad experience with all the aluminum style the wi oxidase after some time and difficult to work with, only the robart quick connectors and the festo style ones
