Skymaster light set/controller
Help!
I have a friend with a SM model using SkyMaster lights and controller. Any one used the supplied parts? There are splitter boards supplied that pairs of lights go into, and then the main controller. Any pictures of wiring set up? Thanks Dave |
Hello Dave. The little connector hubs are just splitters.
If you take the shrink wrap off the hub then the wire path becomes clear. The controller is parasitic so a switch for power in some form is helpful. I use a Jeti SP06 switch which is not jeti specific. The signal wire going to the SM controller will need the + and - removed or it will pull power from the receiver setup as well. |
J
Thanks! Good to get some info coming the other way 😂 Will pass it on. Dave Just the positive removing! Signal and negative would be normal… |
| All times are GMT -8. The time now is 11:35 PM. |
