Help with Down & Locked retracts.
Need a few clues here. I'm scratch building a scale model, not a jet this time, but as most jets use retracts I'm sure most of the knowledge about retracts will be here. Was given this set of Down & Locked retracts along with the box of smoke & mirrors to make it all work. No instructions at all.
All the screw jack units work fine in both directions when powered with a 4.8 volt receiver pack so that's a start. But how are they controlled at the travel limits up & down? I can understand that other electric retracts have some sort of feedback via the third wire like a servo but these have just two. These were seen as the latest & greatest at one stage but quickly disappeared. Not much positive feed back on them after a Google search. Options: 1/ get some instructions (where?) & try to get them working. 2/ if the screw jack units are not the problem, just the control system, I could control them by other means & chuck the control box. 3/ forget the whole idea & fit a set of Spring Air units which I also have although speed control is not so great with these & a slow retract cycle does look cool. Any advice would be appreciated, thanks in advance!. https://cimg5.ibsrv.net/gimg/www.rcu...96e4153d7a.jpg |
the controller box uses amp load to determine when to stop the cycle.
xicoy, jp, electron, and others sell good retract control box units for 2 wire systems. |
Chuck that controller in the garbo is the first thing to do
Get ya one of the latest Electron controllers and be done with it Most people had issues with D&L controllers , service was bad , lack of communication = D&L went belly up & down the drain |
Were the screw jack units durable & properly engineered and all the issues were just with the control unit?
I don't want to build myself into a corner & carry out lots of chopping & modifying to try to fit something later on. Mount them on carbon adapter plates so I can swap them out later on? |
Originally Posted by Boomerang1
(Post 12822741)
Are the basic mechanisms & screw jacks ok or are they a disaster waiting to happen as well as the box of smoke & mirrors?
I can deal with basic mechanical problems & will have to do some mods anyway. If it's a lost cause I will simply take them fishing & use the Spring Air's. |
swap meet em, at a bargain basement price, after ya bin the control box.
using em as fishing weights might release things ya don't want released into the water... |
| All times are GMT -8. The time now is 04:09 PM. |
